How to change height of the Column Control
Ellie
Ellie posted this 15 April 2014
I'm trying to create the same cell with children as here
http://templates.themler.com/Themes/Detail/1660434
I've added a Column, however I don't know how to change its height.
alt text
Assuming that it can be dynamic and depend on a content it has, I've added a "Text" control. Now I can resize Text control vertically:
alt text
However not horizontally.
Could you please help me clarify these 2 issues to me - how to change the height of the Column, so I have the cell as in the theme provided above, and how to change the length of the Text control.
Rory
Hi, I'm trying to create the same cell with children as here [http://templates.themler.com/Themes/Detail/1660434][1] I've added a Column, however I don't know how to change its height. ![alt text](http://attachments.forum.billiondigital.com/74/74/column.png "column.png") Assuming that it can be dynamic and depend on a content it has, I've added a "Text" control. Now I can resize Text control vertically: ![alt text](http://attachments.forum.billiondigital.com/73/73/with-text-control.png "with-text-control.png") However not horizontally. Could you please help me clarify these 2 issues to me - how to change the height of the Column, so I have the cell as in the theme provided above, and how to change the length of the Text control. Thanks, Rory [1]: http://templates.themler.com/Themes/Detail/1660434
Olivia posted this 15 April 2014
Just an idea.
This could be a Row control with background image (kids). The Row has two Columns. The right column contains a Text Group, for example, with text and button (not control, add button through the context menu). And then fix the height using Text Group bottom margin.
Another idea.
The box with kids is a Header which contains Text Group with a text and button. You can control the Header height in PW.
The "header" with Logo and phone is a Row which contains Headline, Logo, phone etc.
You can affect the row height with, for example, Headline padding.
Just an idea. This could be a Row control with background image (kids). The Row has two Columns. The right column contains a Text Group, for example, with text and button (not control, add button through the context menu). And then fix the height using Text Group bottom margin. Another idea. The box with kids is a Header which contains Text Group with a text and button. You can control the Header height in PW. The "header" with Logo and phone is a Row which contains Headline, Logo, phone etc. You can affect the row height with, for example, Headline padding.
Ellie
Ellie posted this 16 April 2014
Thanks for the ideas! I've tried the first one and it works just fine.
How can I control the width of the Text control? It's stretched all over the column width by default.
Thanks for the ideas! I've tried the first one and it works just fine. How can I control the width of the Text control? It's stretched all over the column width by default.
Is Solution
Olivia posted this 16 April 2014
You can either change the width of the Column which contains the Text Group or open Text Group options in PW >> Group tab >> go to the Options >> Size.
