Hello team,
I’m encountering a strange issue with Themler: when I try to edit a theme the editor stays blank or shows an error message, though everything else seems to be functioning. I’m using X CMS version (WordPress/Joomla) on PHP 8.1. I’ve already tried clearing the browser cache, disabling extensions and switching browsers.
Could you advise:
Which log or debug file should I check for Themler-specific errors?
Is there a known conflict with PHP 8.1, or other server settings (mod_security, safe_mode) that users often run into?
Are there any recent updates or patches I should apply to resolve editor loading problems?
Thanks in advance for your help.
Hello team, I’m encountering a strange issue with Themler: when I try to edit a theme the editor stays blank or shows an error message, though everything else seems to be functioning. I’m using X CMS version (WordPress/Joomla) on PHP 8.1. I’ve already tried clearing the browser cache, disabling extensions and switching browsers. Could you advise: Which log or debug file should I check for Themler-specific errors? Is there a known conflict with PHP 8.1, or other server settings (mod_security, safe_mode) that users often run into? Are there any recent updates or patches I should apply to resolve editor loading problems? Thanks in advance for your help.
