pages are not loading
metineralperen16
metineralperen16 posted this 26 October 2025
The pages aren't loading; the page is completely blank even though I'm logged in. It says, “No results were found.” I need urgent support.
autoskola
autoskola posted this 28 October 2025
Ano mám to samé, i v placeném účtu i v novém. Někde psala podpora, že je to vyřešené a není bohužel
Coquito
Coquito posted this 31 October 2025
I'm having the same problem, both using the Joomla plugin and the Windows app. When I insert a section from the library, a blank page appears with the message "No results were found."
The same problem occurs when using the "Suggest Homepage" or "Suggest Header/Footer" functions.
I'm having the same problem, both using the Joomla plugin and the Windows app. When I insert a section from the library, a blank page appears with the message "No results were found." The same problem occurs when using the "Suggest Homepage" or "Suggest Header/Footer" functions.
