Woocomerce Home Page
andrew34
andrew34 posted this 02 September 2015
How do I modify the home page to look more like the products page? i.e. how do I delete the "posts" area and replace it with a "products" area?
9 Comments
Support Team posted this 03 September 2015
Andrew,
Please see example.
http://templates.themler.com/Themes/Detail/1894193/SkateMore
Thank you!
Andrew, Please see example. http://templates.themler.com/Themes/Detail/1894193/SkateMore Thank you!
andrew34
andrew34 posted this 03 September 2015
Thanks - but I've already started my theme and was wondering what steps I need to take to replicate the home page of SkateMore.
Support Team posted this 07 September 2015
The idea is to put one or several products sliders to the Home page so that some featured products, bestsellers etc. are displayed. For this standard wooCommerce widgets can be put into a proper widget area - the Primary Widget area in our case. The widgets are output with the help of Product Slider controls, each of them can be set up separately. For example, this is how it looks in the example theme:
As for the Posts control. As it is ouput with the help of the Content control, you can try disabling displaying CMS Content for the Home template by going to Sidebars >> CMS Content like this:
Let us know if any additional questions appear.
Hello, The idea is to put one or several products sliders to the Home page so that some featured products, bestsellers etc. are displayed. For this standard wooCommerce widgets can be put into a proper widget area - the Primary Widget area in our case. The widgets are output with the help of Product Slider controls, each of them can be set up separately. For example, this is how it looks in the example theme: !i39.png! As for the Posts control. As it is ouput with the help of the Content control, you can try disabling displaying CMS Content for the Home template by going to **Sidebars** >> **CMS Content** like this: !i40.png! Let us know if any additional questions appear. Sincerely, Nettie, BillionDigital Team
andrew34
andrew34 posted this 09 September 2015
Thanks - that helped a bit. I've set the CMS content to off and dragged a WP Primary Widget Area to the area next to the sidebar. However, there is still a container to the right of the primary widget area I cannot remove and the sidebar somehow has two extra blank columns in it from my dragging and dropping operations. When I try to delete the columns, I get this message:
Model Change
Unable to complete remove. Another operation is in process. Please wait and try again.
This occurs even if I leave it alone a while.
Thanks - that helped a bit. I've set the CMS content to off and dragged a WP Primary Widget Area to the area next to the sidebar. However, there is still a container to the right of the primary widget area I cannot remove and the sidebar somehow has two extra blank columns in it from my dragging and dropping operations. When I try to delete the columns, I get this message: Model Change Unable to complete remove. Another operation is in process. Please wait and try again. This occurs even if I leave it alone a while.
andrew34
scratch that - updating the template fixed the issues.
andrew34
So now I've got a sidebar with a product slide, but also a Main Widget with a product slider. How do I change the Main Widget's product slider to the Products widget - does that have to be done in the admin area of the site?
Support Team posted this 11 September 2015
Hello Andrew,
I'm sorry but I'm not quite sure that I understand you properly. What do you mean by "Main Widget"? May be you mean the Products Grid?
http://attachments.answers.billiondigital.com/253/5253/ProductsGrid.png
If yes, then please refer to this article that describes this control
http://answers.themler.com/articles/4778/products-ecommerce
As for widgets located in various Widget Areas, the widgets could be added, removed under WP admin back end, under Appearance >> Widgets.
Hello Andrew, I'm sorry but I'm not quite sure that I understand you properly. What do you mean by "Main Widget"? May be you mean the Products Grid? http://attachments.answers.billiondigital.com/253/5253/ProductsGrid.png If yes, then please refer to this article that describes this control http://answers.themler.com/articles/4778/products-ecommerce As for widgets located in various Widget Areas, the widgets could be added, removed under WP admin back end, under Appearance >> Widgets. regards, Aileen
andrew34
andrew34 posted this 11 September 2015
Yes, I want to add the products template to the home page but it appears that is not possible :(
Support Team posted this 15 September 2015
Hello Andrew,
you may select the Shop page (the one that outputs products) as Home page under WP admin back end:
Hello Andrew, you may select the Shop page (the one that outputs products) as Home page under WP admin back end: !ProductsAtHome.png! regards, Aileen
