wisdom tooth removal singapore
At FIGS Dental, we understand that wisdom teeth removal can be a daunting process. However, it’s important to take care of your oral health by removing impacted or problematic wisdom teeth.
impacted-molars
What are Wisdom Tooth?
Wisdom teeth, also known as third molars, are the last set of molars to emerge in the back of the mouth. They usually grow in during a person’s late teenage years or early adulthood. While some people never have any issues with their wisdom teeth, others experience pain and discomfort as a result of their emergence.
Wisdom teeth are the third set of molars located at the back of the mouth. Most people have four wisdom teeth, but some may have fewer or none at all. These teeth are called “wisdom teeth” because they usually emerge during a person’s late teenage years or early adulthood, when they are considered to be gaining “wisdom.”
Why is Wisdom Tooth Extraction necessary?
Wisdom tooth extraction is necessary when your wisdom teeth become impacted, meaning they don’t have enough room to emerge properly. Impacted wisdom teeth can cause a range of problems, including:
Pain
Impacted wisdom teeth can cause pain and discomfort in the back of your mouth.Infection
Impacted wisdom teeth can increase the risk of infection and inflammation.Damage to surrounding teeth
Impacted wisdom teeth can push against your other teeth, causing damage and misalignment.Cysts or tumors
In rare cases, impacted wisdom teeth can cause cysts or tumors to form in your jawbone
Read more: wisdom tooth removal singapore
**wisdom tooth removal singapore** At FIGS Dental, we understand that wisdom teeth removal can be a daunting process. However, it’s important to take care of your oral health by removing impacted or problematic wisdom teeth. impacted-molars What are Wisdom Tooth? Wisdom teeth, also known as third molars, are the last set of molars to emerge in the back of the mouth. They usually grow in during a person’s late teenage years or early adulthood. While some people never have any issues with their wisdom teeth, others experience pain and discomfort as a result of their emergence. Wisdom teeth are the third set of molars located at the back of the mouth. Most people have four wisdom teeth, but some may have fewer or none at all. These teeth are called “wisdom teeth” because they usually emerge during a person’s late teenage years or early adulthood, when they are considered to be gaining “wisdom.” Why is Wisdom Tooth Extraction necessary? Wisdom tooth extraction is necessary when your wisdom teeth become impacted, meaning they don’t have enough room to emerge properly. Impacted wisdom teeth can cause a range of problems, including: 1. Pain Impacted wisdom teeth can cause pain and discomfort in the back of your mouth. 2. Infection Impacted wisdom teeth can increase the risk of infection and inflammation. 3. Damage to surrounding teeth Impacted wisdom teeth can push against your other teeth, causing damage and misalignment. 4. Cysts or tumors In rare cases, impacted wisdom teeth can cause cysts or tumors to form in your jawbone Read more: [wisdom tooth removal singapore][1] [1]: https://figsdental.com/wisdom-teeth-removal/
