I have made a Joomla Template and i have no idea, how can i made the background that from top to bottom. In the attached PrintScreen, the background will only show to height in the module, but i will the background from header to footer.
Extension - Expand to bottom for this module/block or sidebar,
Extension - Expand to bottom for this module/block or sidebar,i made this - by the sidbar and by the modul (see printscreens). but on frontsite the background goes not to bottom.
i made this - by the sidbar and by the modul (see printscreens). but on frontsite the background goes not to bottom.I really dont know what do you want. Try to explain it differently formulated.
I really dont know what do you want. Try to explain it differently formulated.Hi
What i want? I wish, that the gradient background on richt sidebar goes from top (under the header) to bottom (at Footer) in all case. this works on "page" template (printscreen "Aufnahme9.jpg"), but not on template "home" (printscreen Aufnahme8.jpg"). you understand now?
Now it is clear. Dont know why it is so, you did all right. Check on all templates if "Expand to bottom" is activated on same places, "Home" too. Right sidebar on all templates needs it to.
Now it is clear. Dont know why it is so, you did all right. Check on all templates if "Expand to bottom" is activated on same places, "Home" too. Right sidebar on all templates needs it to.Just checked on one finished Joomla theme. You probably missed Expand to bottom inside right sidebar on Home template.
Just checked on one finished Joomla theme. You probably missed Expand to bottom inside right sidebar on Home template.sorry, but this not work. i have made the expand in all templates. but on "home" it will not work.
Herzlich Willkommen in Mumpf
Die Gemeinde Mumpf ist ein freundliches und geselliges Dorf. Die wunderschöne Lage direkt am Rhein sowie die Nähe zum Wald als Naherholungsgebiet zeichnet Mumpf als Wohnort positiv aus. Weiter macht die gute Infrastruktur, den Anschluss an den öffentlichen Verkehr sowie an die Autobahnzubringern Mumpf attraktiv.
..then the eypand to bottom will not work.
solution: the expand-function must work not only by a orticle on frontsite - only modul must made the same thing as article.
sorry, but this not work. i have made the expand in all templates. but on "home" it will not work. i have tested view times. i mean, when only a modul is show on "home" (i mean the text in "Aufnahme8.jpg" (this is a module): ----- Herzlich Willkommen in Mumpf Die Gemeinde Mumpf ist ein freundliches und geselliges Dorf. Die wunderschöne Lage direkt am Rhein sowie die Nähe zum Wald als Naherholungsgebiet zeichnet Mumpf als Wohnort positiv aus. Weiter macht die gute Infrastruktur, den Anschluss an den öffentlichen Verkehr sowie an die Autobahnzubringern Mumpf attraktiv. Ein Ausflug auf die Mumpfer Fluh mit Blick über den Rhein bis weit in den Schwarzwald lädt zum Verweilen und Geniessen ein. ----- ..then the eypand to bottom will not work. solution: the expand-function must work not only by a orticle on frontsite - only modul must made the same thing as article.i have set "expand to bottom" on all pages now by modul and sidbar.
but the background is not show to bottom. See Printscreen 1 (Frontsite/Home) and 2 (Page).
it's probably a browser-problem? heere is the result by firefox. Printscreen 1 from Home and 2 from Page. By 1 it is possible, that the expand to bottom not work while only a module in the middle is placed.
but on 2 the expand work.
is use internet explorer 11 from windows 10.
but in google chrome i have the same result with internet explorer 11 - not work.
Hello Guentert Marcel,
I apologize for delay in response.
Could you please provide link to your site and if possible attach your saved theme here.
hi
the link of the site with the Image in right-modul is:
http://web5.login-142.hoststar.ch/cms/aktuell.html
the file from themler is attached.
hi the link of the site with the Image in right-modul is: http://web5.login-142.hoststar.ch/cms/aktuell.html the file from themler is attached.Remove margin from footer and sidebar blocks. You fight against physics.
Remove margin from footer and sidebar blocks. You fight against physics.resulting in an image in a module to do with the footer?
resulting in an image in a module to do with the footer?i have removed the margin from footer and sidebar block. but the Image is still there as Background. removing the margin not help. See:
Attachment: new themler-file
Hello Marcel,
please refer to my response in topic http://answers.themler.com/questions/25099/module-on-right-as-site-background
