If your Themler template is not loading properly in WordPress, the first step is to check theme compatibility with your current PHP and WordPress versions. Outdated PHP, plugins or Themler builds can cause blank pages, broken layouts or missing sections. Disable all non‑essential plugins, switch to a default theme to test, and then reactivate Themler to see if the issue is related to a conflict. Clearing browser cache and any caching/optimization plugins is also important before retesting.
Next, verify file permissions and whether all theme files were uploaded correctly via FTP or the dashboard. A partial upload or server‑side security rule can block key CSS or JS files, which breaks the visual layout. If you manage multiple compliance or documentation pages—such as those explaining your BIS CRS Certificate, BIS registration process or other certifications—make sure the affected templates are using the correct Themler layout and that shortcodes/widgets are supported by your current version. When in doubt, export a backup of your theme, update Themler to the latest build, and reach out to Themler support with error logs or console screenshots for faster diagnosis.
If your Themler template is not loading properly in WordPress, the first step is to check theme compatibility with your current PHP and WordPress versions. Outdated PHP, plugins or Themler builds can cause blank pages, broken layouts or missing sections. Disable all non‑essential plugins, switch to a default theme to test, and then reactivate Themler to see if the issue is related to a conflict. Clearing browser cache and any caching/optimization plugins is also important before retesting. Next, verify file permissions and whether all theme files were uploaded correctly via FTP or the dashboard. A partial upload or server‑side security rule can block key CSS or JS files, which breaks the visual layout. If you manage multiple compliance or documentation pages—such as those explaining your [BIS CRS Certificate][1], BIS registration process or other certifications—make sure the affected templates are using the correct Themler layout and that shortcodes/widgets are supported by your current version. When in doubt, export a backup of your theme, update Themler to the latest build, and reach out to Themler support with error logs or console screenshots for faster diagnosis. [1]: https://www.bl-india.com/services/bis/bis-crs-registration
