magento cross-sell, related products, up-sell
jurjen
jurjen posted this 07 September 2015
I wonder where you stand on including all three categories of cross-selling, up-selling and related products. A few months ago, this was on the developmentlist.
Jurjen
Hi, I wonder where you stand on including all three categories of cross-selling, up-selling and related products. A few months ago, this was on the developmentlist. Regards Jurjen
Support Team posted this 08 September 2015
Hello Jurjen,
Currently all these modules can be displayed in Magento themes:
1. Up-sell products are displayed in the We Also Recommend tab on the product page.
2. Related products can be displayed in the Right Sidebar.
3. Cross-sell products appear in one of Shopping Cart blocks.
Best regards,
Hello Jurjen, Currently all these modules can be displayed in Magento themes: 1. **Up-sell products** are displayed in the We Also Recommend tab on the product page. 2. **Related products** can be displayed in the Right Sidebar. 3. **Cross-sell products** appear in one of Shopping Cart blocks. Best regards, Nettie, BillionDigital Team
jurjen
jurjen posted this 08 September 2015
Hello Nettie,
If you add a normal product-slider to the right Sidebar. You can not delete it. You have to put the slider in a column first.
Then you can delete it.
It is annoying that you can not customize each product slider separately. A slider on your start page would normally be a lot bigger then in your sidebar.
Can you put that on the roadmap. It could work the same way as the other customize this template function.
Jurjen
Hello Nettie, If you add a normal product-slider to the right Sidebar. You can not delete it. You have to put the slider in a column first. Then you can delete it. It is annoying that you can not customize each product slider separately. A slider on your start page would normally be a lot bigger then in your sidebar. Can you put that on the roadmap. It could work the same way as the other customize this template function. Regards Jurjen
jurjen
Hi Nettie,
Correct that. you can not delete the slider. It gets back into the template if you reload the contents.
Hi Nettie, Correct that. you can not delete the slider. It gets back into the template if you reload the contents.
Support Team posted this 09 September 2015
Hi Jurjen,
Each slider can be configured separately using corresponding settings in Magento admin panel: Billion Themler >> [choose your theme] >> Settings >> Sliders:
Here you can set different number of products in slide for different sliders and number of columns for different screens.
As each slider is output from CMS in Sidebars, it should be disabled in a CMS to be not shown. If there are several sliders like on the Home template - please use the setting responsible for enabling/disabling the slider in Slider Settings shown above.
It looks like:
Hi Jurjen, Each slider can be configured separately using corresponding settings in Magento admin panel: Billion Themler >> [choose your theme] >> Settings >> Sliders: !i45.png! Here you can set different number of products in slide for different sliders and number of columns for different screens. As each slider is output from CMS in Sidebars, it should be disabled in a CMS to be not shown. If there are several sliders like on the Home template - please use the setting responsible for enabling/disabling the slider in Slider Settings shown above. It looks like: !i46.png! Sincerely, Nettie, BillionDigital Team
