I am facing an issue where table and blockquote styles are not applying properly in my Joomla template. I have tried different settings but the changes are not showing.
Sometimes it becomes confusing when styles behave differently depending on templates and overrides. Clear step-by-step explanations really help in such cases.
I also found a helpful guide on 8171 Dynamic Survey Check that explains processes in a simple way, which made things easier to understand.
Any suggestions on how to fix this issue?
I am facing an issue where table and blockquote styles are not applying properly in my Joomla template. I have tried different settings but the changes are not showing. Sometimes it becomes confusing when styles behave differently depending on templates and overrides. Clear step-by-step explanations really help in such cases. I also found a helpful guide on [8171 Dynamic Survey Check][1] that explains processes in a simple way, which made things easier to understand. Any suggestions on how to fix this issue? [1]: https://adpportal.com.pk/
