I'm working on Themler desktop.
I'm creating a WordPress theme that depends heavily on different sections showing only on desktop (not mobile) and others only showing on mobile (not desktop).
As I can't seem to paste screenshots in this report I will outline a typical process.
In Desktop View:
Insert>Row
Use the little icons on the Row Arrange section and deselect Tablet and Mobile.
This generally works with almost no bugs. Sometimes despite deselecting Tablet and Mobile it will still show on one or the other (most often Mobile) and I will need to deselect it again.
Very buggy is the following:
Using Mobile View:
Add>Row
Use the little icons on the Row Arrange section and deselect Desktop and Laptop.
Change to desktop view and Row is showing.
Change back to Mobile and of the 4 view icons Desktop, Tablet and Mobile are highlighted.
Deselect desktop and mobile also automatically deselects, leaving only tablet selected.
Manually select Mobile again, and Desktop automatically selects.
It seems that trying to make the object show only in Tablet & Mobile is bugged.
Is there a workaround for this?
Thanks.
PS: I can provide screenshots if needed.
Hi, I'm working on Themler desktop. I'm creating a WordPress theme that depends heavily on different sections showing only on desktop (not mobile) and others only showing on mobile (not desktop). As I can't seem to paste screenshots in this report I will outline a typical process. In Desktop View: Insert>Row Use the little icons on the Row Arrange section and deselect Tablet and Mobile. This generally works with almost no bugs. Sometimes despite deselecting Tablet and Mobile it will still show on one or the other (most often Mobile) and I will need to deselect it again. Very buggy is the following: Using Mobile View: Add>Row Use the little icons on the Row Arrange section and deselect Desktop and Laptop. Change to desktop view and Row is showing. Change back to Mobile and of the 4 view icons Desktop, Tablet and Mobile are highlighted. Deselect desktop and mobile also automatically deselects, leaving only tablet selected. Manually select Mobile again, and Desktop automatically selects. It seems that trying to make the object show only in Tablet & Mobile is bugged. Is there a workaround for this? Thanks. PS: I can provide screenshots if needed.
