header layout
WebIm
WebIm posted this 10 September 2015
Hello.
how I can create a header like the image that I am attaching?
thanks a lot
daniela
enter image description here
Hello. how I can create a header like the image that I am attaching? thanks a lot daniela![enter image description here][1] [1]: http://webimmagine.it/images/layout.jpg
9 Comments
Support Team posted this 10 September 2015
Your image shows eчфседн how you need to position the controls. Please explain what exact difficulties do you have so we could help you.
Hi, Your image shows eчфседн how you need to position the controls. Please explain what exact difficulties do you have so we could help you. Sincerely, Hella BillionDigital Team
WebIm
thanks for the reply.
I'm used to working with Artisteer and I do not have much familiarity with themler the moment.
I would like to create a horizontal menu that contains the logo in the center
I would also superimpose the menu to a position of joomla in which I will insert later a slider
There is a preset?
thanks for the reply. I'm used to working with Artisteer and I do not have much familiarity with themler the moment. I would like to create a horizontal menu that contains the logo in the center I would also superimpose the menu to a position of joomla in which I will insert later a slider There is a preset?
Support Team posted this 14 September 2015
the idea is to create layout like below
following the steps:
1.start from empty Header. It is added at the top of the page.
2.add Row with Columns control (Row1 on the image), set it to have 3 columns;
3.insert Joomla Module Position controls into right and left columns. Later you will open the Joomla admin back end and add modules to created positions (this article describes how to do it http://answers.themler.com/articles/4762/joomla-module-position).
4.insert Row with columns control inside header and located it under the row created at step 2. This is the Row 2 on screenshot;
5.set it to have 3 columns
6.add Image control into the middle column
7.Themler themes does not allow to split menu into two parts. But you may create two menus in Joomla admin back end and use them both as horizontal menus.
8.in Themler add two Horizontal Menu controls into right and left columns. This article explains how to create menu and locate it into proper position in Joomla Themler theme
http://answers.themler.com/articles/5516/how-to-create-horizontal-menus-in-joomla
9.add Slider control to the page and locate it right below the Header area.
If you get any question concerning the steps please let us know.
Hello, the idea is to create layout like below !Layout.png! following the steps: 1.start from empty Header. It is added at the top of the page. 2.add Row with Columns control (Row1 on the image), set it to have 3 columns; 3.insert Joomla Module Position controls into right and left columns. Later you will open the Joomla admin back end and add modules to created positions (this article describes how to do it http://answers.themler.com/articles/4762/joomla-module-position). 4.insert Row with columns control inside header and located it under the row created at step 2. This is the Row 2 on screenshot; 5.set it to have 3 columns 6.add Image control into the middle column 7.Themler themes does not allow to split menu into two parts. But you may create two menus in Joomla admin back end and use them both as horizontal menus. 8.in Themler add two Horizontal Menu controls into right and left columns. This article explains how to create menu and locate it into proper position in Joomla Themler theme http://answers.themler.com/articles/5516/how-to-create-horizontal-menus-in-joomla 9.add Slider control to the page and locate it right below the Header area. If you get any question concerning the steps please let us know. regards, Aileen
ike
ike posted this 23 March 2016
So if you wanted this to be over the top of a Joomla Position. Thought is the logo would be placed in the center of the page, and right below that you would have a banner, banner is 400px high, and want the logo to creep into the banner by about 50px, how would you do that? I have tried setting the zindex throughout the template but it just seems to push the second set of columns down. That's not what I'm looking for at all.
ike
Put the logo in a logo box, right click on the logo box, click on positioning, click on absolute inc columns. Walah!
Support Team posted this 23 March 2016
If you have any other questions, please let us know.
Hi, If you have any other questions, please let us know. Sincerely, Hella
odibohfred
odibohfred posted this 21 June 2016
Is it possible to place two logo on the header using themler for wordpress? that is having one logo on the left and other on the right. if yes, please how?
Yes, you may add two Logo controls and position them differently. For example, in Logo tab >> Positioning set "Float right" for the first logo and "Float left" for the second one.
Hello, Yes, you may add two Logo controls and position them differently. For example, in Logo tab >> Positioning set "Float right" for the first logo and "Float left" for the second one. Sincerely, Nettie, BillionDigital Team
chinahousehold
chinahousehold posted this 07 January 2026
https://www.hssolar.cn/news-37.html
https://www.zazzle.com.au/mbr/238550100850616685
https://zrzutka.pl/en/ejh5j2
https://failiem.lv/chinahousehold/info
https://pad.deckenpfronn.info/s/_VJm3YUQQ
https://dlive.tv/u/bothbest
https://dlive.tv/bothbest
https://jsfiddle.net/g1ha9Lbk/
https://jsfiddle.net/1m0n4utg/
https://lit.link/zh-tw/bothbest
https://portaly.cc/bothbest
https://www.letsknowit.com/bothbest
https://lhub.to/bothbest
https://www.buymusic.club/user/bothbest
https://musics.to/80105fYd7r
https://www.betmma.tips/mma_handicapper.php?ID=170191
https://boss.why3s.cc/boss/home.php?mod=space&uid=244491
https://cone.skima.jp/creators/profile/portfolios/detail?id=2913
https://www.frontendmentor.io/profile/bothbestbamboo
https://store.hacosco.com/users/bothbest/movies
https://ns2.asso-web.com/bothbest
https://education.cwf-fcf.org/IUCNyouth/profile/bothbest
https://www.homepros411.com/blog/how-bamboo-plywood-elevates-minimalist-and-scandinavian-interiors
https://www.homepros411.com/gardena/bamboo-flooring
https://worldaid.eu.org/discussion/profile.php?id=1307036
https://topsitenet.com/profile/bothbest/1411485/
https://www.mightydeals.com/seller/bothbest/biography/
https://escrever.coletivos.org/s/Hy65hy5N-x
https://www.tipntag.com/profile/index/id/bothbest
https://photohito.com/user/profile/215480/
https://utas.me/bothbest
https://utas.me/bothbest/why-nauf-glue-matters-when-choosing-bamboo-plywood-panels-7o0wu1uc
https://cdr.cz/profil/rxwlbhejiw
https://tribelio.page/bothbest
https://www.toprecepty.cz/profil/169601-chinahousehold/
https://hackerspace.govhack.org/profiles/bambooflooring
https://webboard.pl/user-50463.html
https://blog-dir-new.vercel.app/blog/bothbest-bamboo-flooring
https://www.swap-bot.com/user:chinabamboo
https://www.golden-forum.com/memberlist.php?mode=viewprofile&u=217528
https://forum.opnsense.org/index.php?action=profile;area=forumprofile;u=63637
https://www.theconsumersfeedback.com/guestpost/how-modern-solar-panels-stay-efficient-in-extreme-heat
https://www.edufex.com/forums/discussion/general/understanding-nauf-bamboo-plywood-for-healthfocused-renovations
https://bambooflooring.alboompro.com/post/what-makes-moso-bamboo-the-best-species-for-high-quality-plywood
https://kadrmaskreations.com/forum/topic/7-architectural-projects-that-showcase-moso-bamboos-potential/
https://divekeeper.com/forums/discussion/general-discussion/hand-scraped-bamboo-flooring-trends-designers-cant-ignore
https://www.uscgq.com/forum/posts.php?forum=&id=627246
https://bothbestbambooflooring.tawk.help/article/distressed-bamboo-flooring-why-designers-love-this-affordable-style
https://arizonaadam.com/forum/topic/why-raw-bamboo-makes-the-best-chopsticks-natures-purest-choice/
https://forumtransportu.pl/forum/temat/26738
https://www.hssolar.cn/news-37.html https://www.zazzle.com.au/mbr/238550100850616685 https://zrzutka.pl/en/ejh5j2 https://failiem.lv/chinahousehold/info https://pad.deckenpfronn.info/s/_VJm3YUQQ https://dlive.tv/u/bothbest https://dlive.tv/bothbest https://jsfiddle.net/g1ha9Lbk/ https://jsfiddle.net/1m0n4utg/ https://lit.link/zh-tw/bothbest https://portaly.cc/bothbest https://www.letsknowit.com/bothbest https://lhub.to/bothbest https://www.buymusic.club/user/bothbest https://musics.to/80105fYd7r https://www.betmma.tips/mma_handicapper.php?ID=170191 https://boss.why3s.cc/boss/home.php?mod=space&uid=244491 https://cone.skima.jp/creators/profile/portfolios/detail?id=2913 https://www.frontendmentor.io/profile/bothbestbamboo https://store.hacosco.com/users/bothbest/movies https://ns2.asso-web.com/bothbest https://education.cwf-fcf.org/IUCNyouth/profile/bothbest https://www.homepros411.com/blog/how-bamboo-plywood-elevates-minimalist-and-scandinavian-interiors https://www.homepros411.com/gardena/bamboo-flooring https://worldaid.eu.org/discussion/profile.php?id=1307036 https://topsitenet.com/profile/bothbest/1411485/ https://www.mightydeals.com/seller/bothbest/biography/ https://escrever.coletivos.org/s/Hy65hy5N-x https://www.tipntag.com/profile/index/id/bothbest https://photohito.com/user/profile/215480/ https://utas.me/bothbest https://utas.me/bothbest/why-nauf-glue-matters-when-choosing-bamboo-plywood-panels-7o0wu1uc https://cdr.cz/profil/rxwlbhejiw https://tribelio.page/bothbest https://www.toprecepty.cz/profil/169601-chinahousehold/ https://hackerspace.govhack.org/profiles/bambooflooring https://webboard.pl/user-50463.html https://blog-dir-new.vercel.app/blog/bothbest-bamboo-flooring https://www.swap-bot.com/user:chinabamboo https://www.golden-forum.com/memberlist.php?mode=viewprofile&u=217528 https://forum.opnsense.org/index.php?action=profile;area=forumprofile;u=63637 https://www.theconsumersfeedback.com/guestpost/how-modern-solar-panels-stay-efficient-in-extreme-heat https://www.edufex.com/forums/discussion/general/understanding-nauf-bamboo-plywood-for-healthfocused-renovations https://bambooflooring.alboompro.com/post/what-makes-moso-bamboo-the-best-species-for-high-quality-plywood https://kadrmaskreations.com/forum/topic/7-architectural-projects-that-showcase-moso-bamboos-potential/ https://divekeeper.com/forums/discussion/general-discussion/hand-scraped-bamboo-flooring-trends-designers-cant-ignore https://www.uscgq.com/forum/posts.php?forum=&id=627246 https://bothbestbambooflooring.tawk.help/article/distressed-bamboo-flooring-why-designers-love-this-affordable-style https://arizonaadam.com/forum/topic/why-raw-bamboo-makes-the-best-chopsticks-natures-purest-choice/ https://forumtransportu.pl/forum/temat/26738
