magento related-products checkbox
jurjen
jurjen posted this 10 September 2015
Why is there a checkbox with the product-slider in the related-product area of magento.
I can not seem to be able to select it in the Themler UI. So I can not format it.
Does it have a function or is this a bug?
See attached pic.
Jurjen
Why is there a checkbox with the product-slider in the related-product area of magento. I can not seem to be able to select it in the Themler UI. So I can not format it. Does it have a function or is this a bug? See attached pic. Regards Jurjen
23 Comments
Support Team posted this 11 September 2015
The checkbox next to each related product functions correctly on my end: please try checking it in Live Preview. In Themler the checkbox can be checked by right-clicking it and clicking Open Link:
Relating styling of the checkbox - currently it cannot be styled in Themler. However this possibility is planned to be added in future. Please follow Themler updates.
Best regards,
Hello, The checkbox next to each related product functions correctly on my end: please try checking it in Live Preview. In Themler the checkbox can be checked by right-clicking it and clicking Open Link: !i53.png! Relating styling of the checkbox - currently it cannot be styled in Themler. However this possibility is planned to be added in future. Please follow Themler updates. Best regards, Nettie, BillionDigital Team
jurjen
jurjen posted this 11 September 2015
Hi Nettie,
the checkbox is to select multiple items and add them to the cart. Then you probably need to have a button in your slider?
Jurjen
Hi Nettie, the checkbox is to select multiple items and add them to the cart. Then you probably need to have a button in your slider? Regards Jurjen
Hi Jurjen,
Thanks, I see what you mean. I have asked developers about this issue and will keep you posted on it.
Hi Jurjen, Thanks, I see what you mean. I have asked developers about this issue and will keep you posted on it. Sincerely, Nettie, BillionDigital Team
jurjen
Hi Nettie,
no problem. For now I just hide it with additional CSS code.
As you can see I have raised a number of issues the last few days. I have a few customers now, for whom I use Themler to create as much as possible. (Wordpress/Woocommerce/Magento). And I am pushing to the edge of the functionality of Themler.
The option to include CMS code has helped a lot, to keep most of the development within Themler. Without the need to change files after I am done with creating the theme. This is a huge step forward in maintainability.
I have some ideas on functionality that would almost reduce the need of editing things outside of themler. Shall I put my ideas in a separate item? Also some ideas on billionphotos.
Jurjen
Hi Nettie, no problem. For now I just hide it with additional CSS code. As you can see I have raised a number of issues the last few days. I have a few customers now, for whom I use Themler to create as much as possible. (Wordpress/Woocommerce/Magento). And I am pushing to the edge of the functionality of Themler. The option to include CMS code has helped a lot, to keep most of the development within Themler. Without the need to change files after I am done with creating the theme. This is a huge step forward in maintainability. I have some ideas on functionality that would almost reduce the need of editing things outside of themler. Shall I put my ideas in a separate item? Also some ideas on billionphotos. Regards Jurjen
Support Team posted this 14 September 2015
Hello Jurjen,
First of all thank you for you interest and input! We really appreciate it. I would recommend you to create separate topics for different suggestions as it would be easier to communicate on each topic and to vote for it if necessary.
Relating the issue in question: our developers have explained that it should work in the following way: when the products in Related Product are marked in checkboxes, than by clicking the "Add to Cart" button next to the main product, they are added to cart together. Currently developers are working on fixing the issues so that it works as described. I will let you know about any news on it.
Hello Jurjen, First of all thank you for you interest and input! We really appreciate it. I would recommend you to create separate topics for different suggestions as it would be easier to communicate on each topic and to vote for it if necessary. Relating the issue in question: our developers have explained that it should work in the following way: when the products in Related Product are marked in checkboxes, than by clicking the "Add to Cart" button next to the main product, they are added to cart together. Currently developers are working on fixing the issues so that it works as described. I will let you know about any news on it. Sincerely, Nettie, BillionDigital Team
jurjen
jurjen posted this 14 September 2015
Hi Nettie,
thank you. I suggest you remove the checkbox if no button is used in the design.
Jurjen
Hi Nettie, thank you. I suggest you remove the checkbox if no button is used in the design. Regards Jurjen
Support Team posted this 15 September 2015
Hi Jurjen,
The idea is to make it possible to add one or more extra products alongside the main product without any need to navigate to another product pages. However yes, I suppose, the "Add to Cart" buttons will be removed from this block. In my view, without a checkbox it would be not so easy to add extra items to a main one and to accept it as a single purchase (for a customer) - for example, when showing some accessories as Related products. Please correct me if I'm missing the point.
Hi Jurjen, The idea is to make it possible to add one or more extra products alongside the main product without any need to navigate to another product pages. However yes, I suppose, the "Add to Cart" buttons will be removed from this block. In my view, without a checkbox it would be not so easy to add extra items to a main one and to accept it as a single purchase (for a customer) - for example, when showing some accessories as Related products. Please correct me if I'm missing the point. Thank you, Nettie, BillionDigital Team
jurjen
jurjen posted this 22 September 2015
I think the idea is OK. The implementation to use a product slider is not such a good idea in my opinion.
It would be of great value of if you can create a product list function as a block type. This block you can then include on pages. With settings you could create the select statement. (manufacturer, category, etc).
Also custom templates with a custom name would then be a great asset to magento themler.
For instance for creating a page that list products of a certain manufacturer, or a page to show all manufacturers.
I do not think people will select multiple products from a slider. That is not common in webshops. Add to cart with javascript or AJAX is more common.
Just a few thoughts.
Jurjen
Hi, I think the idea is OK. The implementation to use a product slider is not such a good idea in my opinion. It would be of great value of if you can create a product list function as a block type. This block you can then include on pages. With settings you could create the select statement. (manufacturer, category, etc). Also custom templates with a custom name would then be a great asset to magento themler. For instance for creating a page that list products of a certain manufacturer, or a page to show all manufacturers. I do not think people will select multiple products from a slider. That is not common in webshops. Add to cart with javascript or AJAX is more common. Just a few thoughts. Regards Jurjen
Support Team posted this 23 September 2015
Hi Jurjen,
  1. As for Related products and your suggestion in general - thanks for this. I have forwarded it to our developers for consideration.
  2. We are working on Custom Templates for Magento. The feature should be available in some of next updates. Custom Templates can already be used in Wordpress, Joomla, Prestashop and Drupal.
Best regards,
Hi Jurjen, 1. As for Related products and your suggestion in general - thanks for this. I have forwarded it to our developers for consideration. 2. We are working on Custom Templates for Magento. The feature should be available in some of next updates. Custom Templates can already be used in Wordpress, Joomla, Prestashop and Drupal. Best regards, Nettie, BillionDigital Team
jurjen
jurjen posted this 24 September 2015
Hi Nettie,
great. I have used the feature in Wordpress and Woocommerce with great succes.
Jurjen
Hi Nettie, great. I have used the feature in Wordpress and Woocommerce with great succes. Jurjen
lidibi9614
lidibi9614 posted this 20 March 2025
If you have a desire to play online, you can easily try this game online - Two Up Casino, incredibly interesting and attractive to me personally, because I haven't played online in our country for a long time in something worthwhile, and there are many pleasant games that you can try as well as here - Two Up Casino. I just couldn't resist, this site is very tempting, and very cool as I found out later.
If you have a desire to play online, you can easily try this game online - [Two Up Casino][1], incredibly interesting and attractive to me personally, because I haven't played online in our country for a long time in something worthwhile, and there are many pleasant games that you can try as well as here - Two Up Casino. I just couldn't resist, this site is very tempting, and very cool as I found out later. [1]: https://two-up-casino-australia.com
California Business Journal
California Business Journal posted this 16 May 2025
If you're asking is online sports betting legal in California, the answer is no. Discover why California has not yet legalized online sports betting and how the ongoing legal and political challenges are delaying progress.
If you're asking [is online sports betting legal in California][1], the answer is no. Discover why California has not yet legalized online sports betting and how the ongoing legal and political challenges are delaying progress. [1]: https://calbizjournal.com/is-sports-betting-legal-in-california-and-why-do-native-american-tribes-oppose-sports-betting-in-california/
Lecomptoirdumedicamentbleu
Lecomptoirdumedicamentbleu posted this 16 May 2025
Regards Lecomptoirdumedicamentbleu
thank you. I suggest you remove the checkbox if no button is used in the design. Regards [Lecomptoirdumedicamentbleu][1] [1]: https://lecomptoirdumedicamentbleu.com/
williumjames786
williumjames786 posted this 09 August 2025
Magento tweaks can be tricky, but sometimes the fun comes from exploring outside the box. If you’re taking a break from debugging related-product checkboxes, you might want to visit here and check out something a bit more entertaining.
Magento tweaks can be tricky, but sometimes the fun comes from exploring outside the box. If you’re taking a break from debugging related-product checkboxes, you might want to [visit here][1] and check out something a bit more entertaining. [1]: http://spribewin.com
williumjames786
williumjames786 posted this 11 September 2025
Magento tweaks can definitely be tricky at times! For those who also enjoy a bit of entertainment outside development, X666 Game is a fun option for betting and casino play.
Magento tweaks can definitely be tricky at times! For those who also enjoy a bit of entertainment outside development, [X666 Game][1] is a fun option for betting and casino play. [1]: https://x666game.app/
williumjames786
williumjames786 posted this 19 September 2025
Magento tweaks can be confusing sometimes, especially with related-product checkboxes. If you need a quick break from coding, you might also want to check out Aliwin789 for some betting game fun.
Magento tweaks can be confusing sometimes, especially with related-product checkboxes. If you need a quick break from coding, you might also want to check out [Aliwin789][1] for some betting game fun. [1]: https://aliwin789.com.pk/
wikas23897
wikas23897 posted this 27 October 2025
Install the latest DS4Windows driver update to keep your controller running perfectly with full system compatibility.
Install the latest [DS4Windows driver update][1] to keep your controller running perfectly with full system compatibility. [1]: https://ds4windows.to/
chinahousehold
chinahousehold posted this 26 January 2026
https://nordwit.com/bothbest
https://backtowork.gr/employer/bothbest/
https://app.parler.com/bothbest
https://www.chillsubs.com/profile/bothbest
https://bothbest.mypixieset.com/
https://classmill.com/bambooflooring
http://www.empregosaude.pt/en/author/bothbest/
https://copynotes.be/shift4me/forum/user-40910.html
https://www.developpez.net/forums/u1859473/bothbest
https://www.developpez.com/user/profil/1859473/bothbest
https://beatsaver.com/playlists/1122549
https://streamelements.com/chinabamboo666/
https://www.twitch.tv/chinabamboo666
https://forums.qhimm.com/index.php?action=profile;area=summary;u=89312
https://tilengine.org/forum/member.php?action=profile&uid=142939
https://www.mycomics.de/profil/bothbest.html
https://www.xibeiwujin.com/home.php?mod=space&uid=2298686&do=profile&from=space
https://collectednotes.com/bothbest/the-cultural-story-behind-bamboo-and-why-it-belongs-in-your-home
https://forum.emrpg.com/home.php?mod=space&uid=1485615&do=profile
https://www.sanjose.com/bothbest-bamboo-flooring-b39018216
http://forum.attractmode.org/index.php?action=profile;u=19607
https://exploratory.io/author/pRJ3Tbd6rA
https://forum.verysync.com/home.php?mod=space&uid=143378
https://vs.cga.gg/user/238866
https://guides.co/g/caramel-strand-woven-bamboo-flooring
https://devhunt.org/@bothbest
https://rufox.ru/bothbest/info/
https://rufox.ru/adverts/market/one/1383/
https://rufox.ru/meetings/244/
https://www.skillboxes.com/business/profile/flooringbamboo52
https://forum.thestrategystory.com/author/bothbest/
https://www.stencyl.com/users/index/1312535
https://worldvectorlogo.com/profile/flooring-bamboo
https://www.bahamaslocal.com/userprofile/279386/bothbest.html
https://hire.digitalscholar.in/candidate/chinahousehold/
https://eggs.mu/artist/chinabamboo
https://linksta.cc/@chinabamboo
https://www.trialsitenews.com/p/bothbest
https://linkstack.lgbt/@bothbest
https://nordwit.com/bothbest https://backtowork.gr/employer/bothbest/ https://app.parler.com/bothbest https://www.chillsubs.com/profile/bothbest https://bothbest.mypixieset.com/ https://classmill.com/bambooflooring http://www.empregosaude.pt/en/author/bothbest/ https://copynotes.be/shift4me/forum/user-40910.html https://www.developpez.net/forums/u1859473/bothbest https://www.developpez.com/user/profil/1859473/bothbest https://beatsaver.com/playlists/1122549 https://streamelements.com/chinabamboo666/ https://www.twitch.tv/chinabamboo666 https://forums.qhimm.com/index.php?action=profile;area=summary;u=89312 https://tilengine.org/forum/member.php?action=profile&uid=142939 https://www.mycomics.de/profil/bothbest.html https://www.xibeiwujin.com/home.php?mod=space&uid=2298686&do=profile&from=space https://collectednotes.com/bothbest/the-cultural-story-behind-bamboo-and-why-it-belongs-in-your-home https://forum.emrpg.com/home.php?mod=space&uid=1485615&do=profile https://www.sanjose.com/bothbest-bamboo-flooring-b39018216 http://forum.attractmode.org/index.php?action=profile;u=19607 https://exploratory.io/author/pRJ3Tbd6rA https://forum.verysync.com/home.php?mod=space&uid=143378 https://vs.cga.gg/user/238866 https://guides.co/g/caramel-strand-woven-bamboo-flooring https://devhunt.org/@bothbest https://rufox.ru/bothbest/info/ https://rufox.ru/adverts/market/one/1383/ https://rufox.ru/meetings/244/ https://www.skillboxes.com/business/profile/flooringbamboo52 https://forum.thestrategystory.com/author/bothbest/ https://www.stencyl.com/users/index/1312535 https://worldvectorlogo.com/profile/flooring-bamboo https://www.bahamaslocal.com/userprofile/279386/bothbest.html https://hire.digitalscholar.in/candidate/chinahousehold/ https://eggs.mu/artist/chinabamboo https://linksta.cc/@chinabamboo https://www.trialsitenews.com/p/bothbest https://linkstack.lgbt/@bothbest
cinatid716
cinatid716 posted this 23 April 2026
Before downloading or playing, always ensure that you are using a reliable and secure source 92 dadu Pakistan. Avoid unofficial links and protect your personal information while registering or playing online.
Before downloading or playing, always ensure that you are using a reliable and secure source [92 dadu Pakistan][1]. Avoid unofficial links and protect your personal information while registering or playing online. [1]: https://92daduu.com.pk/
piyor15640
piyor15640 posted this 07 May 2026
This demand has led to the rise of third-party platforms like Happy Mod APK, which has gained massive popularity among users who want modified versions of apps and games.
This demand has led to the rise of third-party platforms like [Happy Mod APK][1], which has gained massive popularity among users who want modified versions of apps and games. [1]: https://happymoddd.com.in/
