Hi Team,
I’m working on a WordPress website for my brand studiorigin, and I want to create a birthday-themed homepage update for the month of May.
I need help with:
  • Changing homepage banners
  • Adding birthday-themed design elements
  • Keeping the website responsive
  • Making sure existing layout/design doesn’t break
I’m currently using Themler for customization and would like guidance on the best way to implement this.
Should I modify the theme directly or use another approach?
Thanks.
Hi Team, I’m working on a WordPress website for my brand **[studiorigin][1]**, and I want to create a birthday-themed homepage update for the month of May. I need help with: * Changing homepage banners * Adding birthday-themed design elements * Keeping the website responsive * Making sure existing layout/design doesn’t break I’m currently using Themler for customization and would like guidance on the best way to implement this. Should I modify the theme directly or use another approach? Thanks. [1]: https://www.studiorigin.in/
