Finding a job in the Netherlands can be exciting, but many international candidates struggle with one important step: creating a CV that feels professional, clear, and suitable for Dutch employers.
A CV for the Dutch job market is not always the same as a resume used in the US, UK, India, or other countries. Dutch recruiters often prefer a clean structure, clear work experience, readable sections, and a format that is easy to scan. At the same time, many companies now use Applicant Tracking Systems, so the CV should also be ATS-friendly.
That is why choosing the right English CV template for the Netherlands can make a real difference.
Why CV Templates Matter for Jobs in the Netherlands
Your CV is often the first thing a recruiter sees. Before they read every detail, they quickly check whether your profile looks relevant, organized, and easy to understand.
A good CV template helps with:
Clear presentation of work experience
Easy-to-read skills and education sections
A professional layout for Dutch employers
ATS readability for online applications
Consistent formatting across the whole document
A4 PDF export, which is commonly expected in Europe
For international applicants, this matters even more. You may have strong experience, but if your CV format does not match local expectations, recruiters may not understand your profile quickly enough.
Common CV Problems International Candidates Face
Many job seekers applying in the Netherlands use CVs that are either too long, too visual, or not structured clearly enough.
Some common problems include:
Too many design elements
Two-column layouts that are difficult for ATS systems
Missing Dutch-market sections
Unclear job titles or work experience
Skills listed without context
A resume format copied from another country
No clear link between the CV and the target vacancy
These issues can make a strong candidate look less relevant than they actually are.
Use English CV Templates Built for the Dutch Job Market
To make this easier, WerkCV.nl offers English-friendly CV templates designed for people applying for jobs in the Netherlands.
👉 English CV Templates for Jobs in the Netherlands
The templates are built around a Dutch-market CV structure while still allowing international candidates to write their CV in English.
With WerkCV, you can:
Choose an ATS-friendly CV template
Use a format suitable for Dutch employers
Build your CV in English
Switch templates later if needed
Export your CV as an A4 PDF
Start for free and pay once only when downloading
This is useful for expats, international students, skilled migrants, and professionals applying to Dutch companies.
Which CV Template Should You Choose?
The best template depends on the type of job you are applying for.
For corporate, finance, IT, operations, administration, or serious professional roles, a simple and structured template is usually safer.
For creative, marketing, design, or communication roles, a more modern template can work well, as long as the CV remains readable.
For online applications where ATS systems may scan your CV, choose a plain, keyword-friendly layout with standard headings like:
Profile
Work Experience
Education
Skills
Languages
Certifications
Projects
A CV should look professional, but it should not sacrifice readability for design.
Example: Why Structure Matters
Imagine two candidates applying for the same role.
Candidate A has strong experience but uses a complex visual CV with icons, tables, and unclear sections.
Candidate B has similar experience but uses a clean CV template with clear headings, relevant keywords, and readable bullet points.
In many cases, Candidate B has a better chance of being understood quickly by both recruiters and ATS systems.
This does not mean your CV should be boring. It means the design should support your content, not hide it.
Who Can Use These Templates?
WerkCV’s English CV templates are useful for:
Expats applying for jobs in the Netherlands
International students looking for internships or starter roles
Indian, EU, UK, US, and other professionals targeting Dutch companies
Skilled migrants preparing applications
Job seekers who want an English CV with Dutch-market structure
Candidates who want a simple, no-subscription CV builder
Whether you are applying in Amsterdam, Rotterdam, Utrecht, Eindhoven, The Hague, or remotely to Dutch companies, having a clear CV format can help recruiters understand your profile faster.
Final Thoughts
A good CV template will not get the job for you by itself, but it can help make your experience easier to read, easier to scan, and easier to match with the vacancy.
If you are applying for jobs in the Netherlands and want an English CV that follows Dutch-market expectations, try the templates here:
https://werkcv.nl/en/templates
Choosing the right CV structure today can make your next application look more professional, focused, and recruiter-friendly.
Finding a job in the Netherlands can be exciting, but many international candidates struggle with one important step: creating a CV that feels professional, clear, and suitable for Dutch employers. A CV for the Dutch job market is not always the same as a resume used in the US, UK, India, or other countries. Dutch recruiters often prefer a clean structure, clear work experience, readable sections, and a format that is easy to scan. At the same time, many companies now use Applicant Tracking Systems, so the CV should also be ATS-friendly. That is why choosing the right English CV template for the Netherlands can make a real difference. Why CV Templates Matter for Jobs in the Netherlands Your CV is often the first thing a recruiter sees. Before they read every detail, they quickly check whether your profile looks relevant, organized, and easy to understand. A good CV template helps with: Clear presentation of work experience Easy-to-read skills and education sections A professional layout for Dutch employers ATS readability for online applications Consistent formatting across the whole document A4 PDF export, which is commonly expected in Europe For international applicants, this matters even more. You may have strong experience, but if your CV format does not match local expectations, recruiters may not understand your profile quickly enough. Common CV Problems International Candidates Face Many job seekers applying in the Netherlands use CVs that are either too long, too visual, or not structured clearly enough. Some common problems include: Too many design elements Two-column layouts that are difficult for ATS systems Missing Dutch-market sections Unclear job titles or work experience Skills listed without context A resume format copied from another country No clear link between the CV and the target vacancy These issues can make a strong candidate look less relevant than they actually are. Use English CV Templates Built for the Dutch Job Market To make this easier, WerkCV.nl offers English-friendly CV templates designed for people applying for jobs in the Netherlands. 👉 [English CV Templates][1] for Jobs in the Netherlands The templates are built around a Dutch-market CV structure while still allowing international candidates to write their CV in English. With WerkCV, you can: Choose an ATS-friendly CV template Use a format suitable for Dutch employers Build your CV in English Switch templates later if needed Export your CV as an A4 PDF Start for free and pay once only when downloading This is useful for expats, international students, skilled migrants, and professionals applying to Dutch companies. Which CV Template Should You Choose? The best template depends on the type of job you are applying for. For corporate, finance, IT, operations, administration, or serious professional roles, a simple and structured template is usually safer. For creative, marketing, design, or communication roles, a more modern template can work well, as long as the CV remains readable. For online applications where ATS systems may scan your CV, choose a plain, keyword-friendly layout with standard headings like: Profile Work Experience Education Skills Languages Certifications Projects A CV should look professional, but it should not sacrifice readability for design. Example: Why Structure Matters Imagine two candidates applying for the same role. Candidate A has strong experience but uses a complex visual CV with icons, tables, and unclear sections. Candidate B has similar experience but uses a clean CV template with clear headings, relevant keywords, and readable bullet points. In many cases, Candidate B has a better chance of being understood quickly by both recruiters and ATS systems. This does not mean your CV should be boring. It means the design should support your content, not hide it. Who Can Use These Templates? WerkCV’s English CV templates are useful for: Expats applying for jobs in the Netherlands International students looking for internships or starter roles Indian, EU, UK, US, and other professionals targeting Dutch companies Skilled migrants preparing applications Job seekers who want an English CV with Dutch-market structure Candidates who want a simple, no-subscription CV builder Whether you are applying in Amsterdam, Rotterdam, Utrecht, Eindhoven, The Hague, or remotely to Dutch companies, having a clear CV format can help recruiters understand your profile faster. Final Thoughts A good CV template will not get the job for you by itself, but it can help make your experience easier to read, easier to scan, and easier to match with the vacancy. If you are applying for jobs in the Netherlands and want an English CV that follows Dutch-market expectations, try the templates here: https://werkcv.nl/en/templates Choosing the right CV structure today can make your next application look more professional, focused, and recruiter-friendly. [1]: https://werkcv.nl/en/templates
