k2 images are not responsive
faithbloom
faithbloom posted this 12 September 2015
The images embedded in a K2 article are not responsive. When the browser window is made smaller the images stays same size hence part of the image is cut off. This was fine in Artisteer.
Please look into this. Thanks you
The images embedded in a K2 article are not responsive. When the browser window is made smaller the images stays same size hence part of the image is cut off. This was fine in Artisteer. Please look into this. Thanks you
8 Comments
philippe.pphantom
philippe.pphantom posted this 13 September 2015
i think that themler is not compatible at all with all joomla CCK ( K2, Flexicontent, Seblod, etc) and in comparison with Artisteer it is a clear regression because without a CCK it's a bit difficult to buid a serious site.
The software can't work of you have not standard article, categories and menu online ...( a trick consist to generate Joomla with all the default example).
The design has been conceived only for very simple Joomla site; they sell us a new software with possibilities far beyond Artisteer, in fact it's not the case at all; it's the case for some function ( you can add position by example) but with all the limitations at the end we have a lot of less possibilities and more, the productivity is very weak because for simple things we have to spend a lot of more time than with Artisteer; by principle is we use this kind of software it is to replace doing a template manually, it's to gain productivity.
It's like the designer of this software lack completely of global view without a clear line to follow ...
It's a pity because beyond that we have good ideas ...
i think that themler is not compatible at all with all joomla CCK ( K2, Flexicontent, Seblod, etc) and in comparison with Artisteer it is a clear regression because without a CCK it's a bit difficult to buid a serious site. The software can't work of you have not standard article, categories and menu online ...( a trick consist to generate Joomla with all the default example). The design has been conceived only for very simple Joomla site; they sell us a new software with possibilities far beyond Artisteer, in fact it's not the case at all; it's the case for some function ( you can add position by example) but with all the limitations at the end we have a lot of less possibilities and more, the productivity is very weak because for simple things we have to spend a lot of more time than with Artisteer; by principle is we use this kind of software it is to replace doing a template manually, it's to gain productivity. It's like the designer of this software lack completely of global view without a clear line to follow ... It's a pity because beyond that we have good ideas ...
faithbloom
faithbloom posted this 13 September 2015
This is a problem on a live website.
It does not look good for my client and major source of concern for me. Please Themler team is there a work around for this?
This is urgent.
This is a problem on a live website. It does not look good for my client and major source of concern for me. Please Themler team is there a work around for this? This is urgent.
pattygalelive
pattygalelive posted this 13 September 2015
I was having a problem with responsive images and what I discovered is that I actually had to turn responsive on for images. Seems silly, I know. Should be automatic in this day of mobile. I accidentally discovered it after being told my Themler support something totally different.
Anyway... take a look at my screenshot attached where I have the arrows. You have to turn it on for both the blog page and post page. Click where it says 'responsive' to turn it on.
I was having a problem with responsive images and what I discovered is that I actually had to turn responsive on for images. Seems silly, I know. Should be automatic in this day of mobile. I accidentally discovered it after being told my Themler support something totally different. Anyway... take a look at my screenshot attached where I have the arrows. You have to turn it on for both the blog page and post page. Click where it says 'responsive' to turn it on.
Support Team posted this 15 September 2015
Hello guys,
I'd recommend that you try to specify image size as described in the topic http://answers.themler.com/questions/5110/responsive-design to output images properly on different screen sizes.
If it does not help please provide link to any page that demonstrates the issue.
Hello guys, I'd recommend that you try to specify image size as described in the topic http://answers.themler.com/questions/5110/responsive-design to output images properly on different screen sizes. If it does not help please provide link to any page that demonstrates the issue. Regards, Aileen
faithbloom
faithbloom posted this 22 September 2015
Thank you very much for your guidance. None of the suggested solutions worked for me.
http://www.awesomescreenshot.com/image/596919/70a4c56ee21c6d9d51b4e8efe360cd47
Here this link to the page
http://purekernel.codelogixhost1.co.uk/coaching/it-service-management.html
Please fix this Themler. This worked OK on Artisteer, all I did on artisteer was to add an image the framework took care of the rest. Why is this very difficult?
Hello, Thank you very much for your guidance. None of the suggested solutions worked for me. http://www.awesomescreenshot.com/image/596919/70a4c56ee21c6d9d51b4e8efe360cd47 Here this link to the page http://purekernel.codelogixhost1.co.uk/coaching/it-service-management.html Please fix this Themler. This worked OK on Artisteer, all I did on artisteer was to add an image the framework took care of the rest. Why is this very difficult?
jrgweb
jrgweb posted this 22 September 2015
See this thread!!
http://answers.themler.com/questions/28965/joomla-k2-images-not-responsive
See this thread!! http://answers.themler.com/questions/28965/joomla-k2-images-not-responsive
Support Team posted this 23 September 2015
As I see, you have added an extra code in the template so the image is responsive now.
Let us know if the issue still exists.
Hi, As I see, you have added an extra code in the template so the image is responsive now. Let us know if the issue still exists. Sincerely, Hella
faithbloom
faithbloom posted this 23 September 2015
This http://answers.themler.com/questions/28965/joomla-k2-images-not-responsive works at the moment with no obvious side effect. so good.
