You can migrate PST to Office 365 directly to its mailbox via use of two ways that is automatic and manual. Quick & secure solution will be depends on you're migration, whether you are going to migrate a single mailbox or bulk PST file data. Below are short description and steps of both automatic & manual solution.
To automatically, with full security of data integrity and instant migration without freeze, you can try BitRecover PST Converter to transfer PST to Office 365. Follow listed below steps carefully to move PST to Office 365.
- Open this automated program on PC.
- Choose select file option and
next.
- Select mailbox folders of PST files & hit next. Now, set
- Office 365 as saving option and enter login id with password.
- Lastly, click on convert button to start quick conversion.
If you use automatic solution then you will migrate single and bulk PST file at once, & will save your time. But, if you don't want to go with automatic solution then you can try listed below steps of manual method.
- Open Outlook on your computer.
- Click on file, choose Open & Export option.
- Then, choose import from another file option and click next.
- Select, Outlook Data File (.pst), hit next, select stored PST to import inside the Outlook.
- After that, wait for few minutes to completely import.
- Then, go to file and click on add account button.
- Now enter your Office 365 id with their password to configure.
- After that, wait to sync completely.
- Then, restart your Outlook application.
- Create new folder inside the configured Office 365 account.
- After that, go to your main account where you have PST file.
- Then, choose Inbox or sent folder, press CTRL + A to select all emails,
- Now drag and drop all the emails inside newly created folder inside Office 365.
- Finally, repeat this process till completion of migration.
Done, while using both solutions you will migrate PST to Office 365, but we suggest if you have large number of email data then manual method is not use full, in that case you can go with automated solution.
To automatically, with full security of data integrity and instant migration without freeze, you can try **[BitRecover PST Converter][1]** to transfer PST to Office 365. Follow listed below steps carefully to move PST to Office 365.
1. Open this automated program on PC.
2. Choose select file option and
next.
3. Select mailbox folders of PST files & hit next. Now, set
4. Office 365 as saving option and enter login id with password.
5. Lastly, click on convert button to start quick conversion.
1. Open Outlook on your computer.
2. Click on file, choose Open & Export option.
3. Then, choose import from another file option and click next.
4. Select, Outlook Data File (.pst), hit next, select stored PST to import inside the Outlook.
5. After that, wait for few minutes to completely import.
6. Then, go to file and click on add account button.
7. Now enter your Office 365 id with their password to configure.
8. After that, wait to sync completely.
9. Then, restart your Outlook application.
10. Create new folder inside the configured Office 365 account.
11. After that, go to your main account where you have PST file.
12. Then, choose Inbox or sent folder, press CTRL + A to select all emails,
13. Now drag and drop all the emails inside newly created folder inside Office 365.
14. Finally, repeat this process till completion of migration.
[1]: https://www.bitrecover.com/pst-converter/
