posted this
16 October 2014
As mentioned above when you work on cloud you can run only two virtual machines with CMS at the same time.
Once you try to run more than two CMSs you should see the following message:
In this window you can close one of the Themlers to run another one.
To keep the changes in the theme click "Theme" menu in Themler >> "Save" to save theme to cloud. It will be available in your profile under Themes tab.
