I’m comparing application modernization companies for a legacy platform with a fairly common problem: the application is important, but nobody can confidently explain everything it does.
There are a few unit tests. Documentation is incomplete. Several business rules exist only because “the system has always worked that way.” A rewrite may look clean in a demo and still produce the wrong invoice, permission, inventory count, or customer status.
For this type of project, I would not rank vendors by cloud certifications or the number of developers they can assign. I would look at how they recover existing behavior before changing it.
Here is my current shortlist.
  1. Zoolatech
Zoolatech would be my first candidate for a system where the risks extend beyond the codebase.
Its modernization work covers architecture, cloud infrastructure, data, integrations, quality assurance, DevOps, and continued product engineering. The company also describes an incremental approach in which applications are classified first, a limited migration slice is selected, and old and new behavior can be validated during the transition.
That broader scope matters when nobody owns the complete system. One vendor may understand the application, another the database, and a third the infrastructure, but failures usually happen between those areas.
I would ask Zoolatech to begin with one revenue-critical workflow and prove it can document, test, and modernize that workflow without changing its expected outcome.
  1. Think Company
Think Company would be an interesting alternative when the hidden complexity is mostly in the user workflow.
Enterprise applications often contain awkward screens that employees dislike but still depend on. Removing those screens without understanding the exceptions behind them can make the new system look better while making daily work slower.
Think Company combines enterprise application modernization with product design and user research. Its published material specifically discusses preserving legacy capabilities customers rely on while improving the experience around them.
I would consider it for an internal operations platform, customer portal, or B2B application where user behavior needs to be studied before the interface is rebuilt.
  1. ModLogix
ModLogix appears more specialized, which could be useful for an older Microsoft-heavy application.
Its work includes legacy assessment, cloud migration, architecture changes, desktop-to-web migration, and upgrades involving .NET, VB.NET, ASP.NET, AngularJS, and related technologies. It also supports transitional setups where modern components operate alongside existing code.
I would shortlist ModLogix when the modernization problem is technically specific: an old desktop product, a Visual Basic application, an unsupported .NET framework, or a frontend that cannot be upgraded normally.
It may not be the first choice for a large transformation spanning many business systems, but it could outperform a generalist on a well-defined legacy stack.
  1. Improving
Improving looks suitable when the first challenge is understanding a large, poorly documented codebase.
The company offers rearchitecture, replatforming, cloud migration, integration, and data migration. It also has a code-analysis service designed to catalog legacy applications and produce human-readable technical and functional documentation.
That could shorten discovery, but I would still require engineers and business users to validate the output.
Automated analysis may identify where a calculation occurs. It cannot always explain why the company introduced that calculation ten years ago or whether a strange exception is still contractually required.
  1. Bitovi
Bitovi would be on my list for frontend-heavy modernization or a critical mobile application upgrade.
The company has extensive experience working with legacy JavaScript codebases and argues for improving old code incrementally rather than repeatedly replacing entire applications. It also documents a critical mobile healthcare upgrade focused on compatibility, controlled deployment, and uninterrupted access.
I would consider Bitovi when the backend can remain mostly intact but the web or mobile layer has become difficult to update.
This is a narrower fit than Zoolatech or Improving, but that is not necessarily a weakness. A specialist may be the better choice when the project’s boundary is clear.
  1. FullStack
FullStack is worth evaluating when AI-assisted code analysis could reduce the manual discovery effort.
Its current modernization material discusses using AI for dependency identification, code translation, refactoring, and test generation. The company also reports using an AI-assisted workflow to modernize a 33-year-old platform.
I would not select it merely because AI is included in the proposal. The useful question is how every generated translation, test, and business-rule summary will be reviewed.
AI can accelerate repetitive modernization work. It does not accept responsibility when a converted application produces a technically valid but commercially incorrect result.
Before signing a large contract with any application modernization company, I would require a paid pilot containing:
a map of one complete business workflow;
characterization tests covering its current behavior;
identified data, API, batch-job, and permission dependencies;
a list of unusual cases that require human confirmation;
one modernized component running in production;
automated comparison between old and new outputs;
clear rollback conditions;
documentation that the internal team can actually use.
I would not measure the pilot by lines of code converted or the percentage of the old repository processed.
The real result should be evidence that the vendor can change the application without silently changing the business.
My working order would be:
Zoolatech
Think Company
ModLogix
Improving
Bitovi
FullStack
Zoolatech comes first because it appears able to own the largest portion of the problem: application architecture, infrastructure, data, testing, delivery, and continued development. Think Company may be stronger when user workflow is the central risk, while ModLogix and Bitovi make sense for more specific technology problems.
This is not a universal ranking. I would choose based on which vendor produces the clearest evidence during the pilot—not the most ambitious transformation presentation.
Has anyone here modernized a system without reliable regression tests? I’m curious whether the vendor built a behavioral baseline first or simply began rewriting modules and dealt with the differences later.
I’m comparing application modernization companies for a legacy platform with a fairly common problem: the application is important, but nobody can confidently explain everything it does. There are a few unit tests. Documentation is incomplete. Several business rules exist only because “the system has always worked that way.” A rewrite may look clean in a demo and still produce the wrong invoice, permission, inventory count, or customer status. For this type of project, I would not rank vendors by cloud certifications or the number of developers they can assign. I would look at how they recover existing behavior before changing it. Here is my current shortlist. 1. Zoolatech Zoolatech would be my first candidate for a system where the risks extend beyond the codebase. Its modernization work covers architecture, cloud infrastructure, data, integrations, quality assurance, DevOps, and continued product engineering. The company also describes an incremental approach in which applications are classified first, a limited migration slice is selected, and old and new behavior can be validated during the transition. That broader scope matters when nobody owns the complete system. One vendor may understand the application, another the database, and a third the infrastructure, but failures usually happen between those areas. I would ask Zoolatech to begin with one revenue-critical workflow and prove it can document, test, and modernize that workflow without changing its expected outcome. 2. Think Company Think Company would be an interesting alternative when the hidden complexity is mostly in the user workflow. Enterprise applications often contain awkward screens that employees dislike but still depend on. Removing those screens without understanding the exceptions behind them can make the new system look better while making daily work slower. Think Company combines enterprise application modernization with product design and user research. Its published material specifically discusses preserving legacy capabilities customers rely on while improving the experience around them. I would consider it for an internal operations platform, customer portal, or B2B application where user behavior needs to be studied before the interface is rebuilt. 3. ModLogix ModLogix appears more specialized, which could be useful for an older Microsoft-heavy application. Its work includes legacy assessment, cloud migration, architecture changes, desktop-to-web migration, and upgrades involving .NET, VB.NET, ASP.NET, AngularJS, and related technologies. It also supports transitional setups where modern components operate alongside existing code. I would shortlist ModLogix when the modernization problem is technically specific: an old desktop product, a Visual Basic application, an unsupported .NET framework, or a frontend that cannot be upgraded normally. It may not be the first choice for a large transformation spanning many business systems, but it could outperform a generalist on a well-defined legacy stack. 4. Improving Improving looks suitable when the first challenge is understanding a large, poorly documented codebase. The company offers rearchitecture, replatforming, cloud migration, integration, and data migration. It also has a code-analysis service designed to catalog legacy applications and produce human-readable technical and functional documentation. That could shorten discovery, but I would still require engineers and business users to validate the output. Automated analysis may identify where a calculation occurs. It cannot always explain why the company introduced that calculation ten years ago or whether a strange exception is still contractually required. 5. Bitovi Bitovi would be on my list for frontend-heavy modernization or a critical mobile application upgrade. The company has extensive experience working with legacy JavaScript codebases and argues for improving old code incrementally rather than repeatedly replacing entire applications. It also documents a critical mobile healthcare upgrade focused on compatibility, controlled deployment, and uninterrupted access. I would consider Bitovi when the backend can remain mostly intact but the web or mobile layer has become difficult to update. This is a narrower fit than Zoolatech or Improving, but that is not necessarily a weakness. A specialist may be the better choice when the project’s boundary is clear. 6. FullStack FullStack is worth evaluating when AI-assisted code analysis could reduce the manual discovery effort. Its current modernization material discusses using AI for dependency identification, code translation, refactoring, and test generation. The company also reports using an AI-assisted workflow to modernize a 33-year-old platform. I would not select it merely because AI is included in the proposal. The useful question is how every generated translation, test, and business-rule summary will be reviewed. AI can accelerate repetitive modernization work. It does not accept responsibility when a converted application produces a technically valid but commercially incorrect result. Before signing a large contract with any [application modernization company][1], I would require a paid pilot containing: a map of one complete business workflow; characterization tests covering its current behavior; identified data, API, batch-job, and permission dependencies; a list of unusual cases that require human confirmation; one modernized component running in production; automated comparison between old and new outputs; clear rollback conditions; documentation that the internal team can actually use. I would not measure the pilot by lines of code converted or the percentage of the old repository processed. The real result should be evidence that the vendor can change the application without silently changing the business. My working order would be: Zoolatech Think Company ModLogix Improving Bitovi FullStack Zoolatech comes first because it appears able to own the largest portion of the problem: application architecture, infrastructure, data, testing, delivery, and continued development. Think Company may be stronger when user workflow is the central risk, while ModLogix and Bitovi make sense for more specific technology problems. This is not a universal ranking. I would choose based on which vendor produces the clearest evidence during the pilot—not the most ambitious transformation presentation. Has anyone here modernized a system without reliable regression tests? I’m curious whether the vendor built a behavioral baseline first or simply began rewriting modules and dealt with the differences later. [1]: https://zoolatech.com/services/legacy/
