I am using Themler to design the front end for a web project that converts black-and-white video into a colorized version.
The current development case is: black and white videos to color
The page needs to support a practical video colorization workflow:
- Upload a black-and-white video
- Show the selected filename, format, and file size
- Display upload and processing progress
- Explain that AI colorization creates estimated colors rather than verified historical colors
- Show the original and colorized video results
- Let users download the processed video
- Keep the layout usable on phones, tablets, and desktop screens
The main design problem is the result section.
I want users to compare the original black-and-white footage with the AI-colorized video without creating two very small video players on mobile. On desktop, a side-by-side layout seems appropriate. On smaller screens, the players should probably stack vertically or switch through tabs.
What is the best way to build this in Themler?
Would you recommend using two responsive HTML5 video elements inside separate columns, or one video area with buttons for switching between the original and colorized versions?
I also need advice on:
- Styling a drag-and-drop video upload area
- Keeping the upload button accessible on mobile
- Displaying progress and processing status without fixed heights
- Preventing layout shifts when the colorized result appears
- Creating a responsive before-and-after comparison section
- Styling HTML5 video controls inside a Themler template
- Keeping the download action visible without using fixed positioning
- Showing file format, duration, and resolution details clearly
The project is focused on black-and-white video colorization, old family footage, historical clips, film restoration, and downloadable colorized video results.
This is a real development case rather than a generic template test, so I would be interested in Themler-compatible solutions that work reliably with dynamic video content and changing processing states.
I am using Themler to design the front end for a web project that converts black-and-white video into a colorized version. The current development case is: [black and white videos to color][1] The page needs to support a practical video colorization workflow: * Upload a black-and-white video * Show the selected filename, format, and file size * Display upload and processing progress * Explain that AI colorization creates estimated colors rather than verified historical colors * Show the original and colorized video results * Let users download the processed video * Keep the layout usable on phones, tablets, and desktop screens The main design problem is the result section. I want users to compare the original black-and-white footage with the AI-colorized video without creating two very small video players on mobile. On desktop, a side-by-side layout seems appropriate. On smaller screens, the players should probably stack vertically or switch through tabs. What is the best way to build this in Themler? Would you recommend using two responsive HTML5 video elements inside separate columns, or one video area with buttons for switching between the original and colorized versions? I also need advice on: * Styling a drag-and-drop video upload area * Keeping the upload button accessible on mobile * Displaying progress and processing status without fixed heights * Preventing layout shifts when the colorized result appears * Creating a responsive before-and-after comparison section * Styling HTML5 video controls inside a Themler template * Keeping the download action visible without using fixed positioning * Showing file format, duration, and resolution details clearly The project is focused on black-and-white video colorization, old family footage, historical clips, film restoration, and downloadable colorized video results. This is a real development case rather than a generic template test, so I would be interested in Themler-compatible solutions that work reliably with dynamic video content and changing processing states. [1]: https://changevideotocolor.com/
