General
- Now Themler supports Safari v.8.0.8 (10600.8.9) and higher.
UI
Section control and 30+ online presets. With Section control you can add ready-to-use section just in a few clicks.
You can also create and save own Section presets and use them in your themes.
If you want to share your Section with other customers you can send it to us and we'll include it in our library of Sections.
The example video that demonstrates how to create Section can be found here.
All Sections are available on templates.themler.comAdded Drag & Drop possibility for Outline.
Improved theme thumbnails - now all items are shown after the animation is finished.
- Added Size option for Slider in PW.
- Added Transform property for Text Options.
- Added the option to Export/Import presets from ZIP.
- Button text can now be edited in the left side Editor bar.
Controls
Added "Center" horizontal align option for all Horizontal Menu:
Improved "Enable Responsive" option for Horizontal Menu control:
Now you can choose the mode to enable responsive.Fixed issue with Fade In animation appearing by Side In in Slider.
- Fixed issue of Sidebar control markup incompatibility with some Firefox versions.
- Fixed issue with Products grid loading slowly if there are many controls in it.
- Fixed issue with "Joomla Module Position is empty" shown for all new positions in Joomla, if a native Joomla module is put in such position.
- Fixed issue with GoogleMaps on SSL secure websites (HTTPS).
- Fixed layout display issue of the Products Subcategories on Products template. Added column options in Woocommerce, Virtuemart and PrestaShop themes.
New Button presets:
Added Type property of the Text control:
Now you can change the type of text in the Text control in two clicks.
CMS
HTML
- Themler HTML CMS is now available.
- Themler for HTML pages is FREE. This version has some limitations
- How to Install HTML Theme
- How To Password Protect Themler HTML Editor
WordPress
- Fixed issue with "Override default theme footer content" option.
- Added option to choose the size of the image used by Post Image control. It's needed to minimize website traffic and Blog page loading speed.
Joomla
- Fixed compatibility issue with "PhocaMap" extension.
- Fixed compatibility issue with captcha in "ChronoForms V5 -Component" extension.
- Removed extra Virtuemart controls (Currency, etc) from the simple joomla themes.
- Fixed issue with Pagination.
Drupal
- Added Custom Templates feature.
PrestaShop
What is Next?
- WordPress Visual Content Editor
- DNN preview. We're working on DNN themes
- We're also working on new UI
- Examples of Top Websites/Pages
- Artisteer HTML themes to Themler themes conversion. We expect to release this feature and new Artisteer update within a week
