AI is being applied across areas such as customer support, document processing, forecasting, fraud detection, workflow automation, and decision-making. But the right solution seems to depend heavily on the business problem, available data, and existing technology infrastructure.
For those who have implemented artificial intelligence solutions in a business environment, which use cases have delivered the most noticeable results?
What factors would you consider before implementing an AI solution, particularly around integration, data requirements, scalability, and ongoing maintenance?
AI is being applied across areas such as customer support, document processing, forecasting, fraud detection, workflow automation, and decision-making. But the right solution seems to depend heavily on the business problem, available data, and existing technology infrastructure. For those who have implemented [artificial intelligence solutions][1] in a business environment, which use cases have delivered the most noticeable results? What factors would you consider before implementing an AI solution, particularly around integration, data requirements, scalability, and ongoing maintenance? [1]: https://appinventiv.com/ai-services-and-solutions/
