below a number of things I would like to see added to Themler (Magento specific)
- Ability to delete a theme. -> After updating themes you might want to delete the old themes, save space on your hosting.
- Productslider -> Layout per productslider. This could function the same way as with other Default or custom styling.
- adding of custom class names -> This could be handy to make specific changes to class
-The ability to format custom classes and display them under styles or on the page they are shown. - Product sorter dropdown. Custom formatting as if it was a menu dropdown.
- Adjust coding of an element. For instance a product headeror the product sale button. Allowing us to change the code from within the tooling. For instance to change an image based upon the language of the store. Or replacing a slider header with an image.
-Custom menu. -> The ability to create a custom menu block and fill the menu with links of our own choice.
I have a lot of other ideas, that would summarize to a combination of themler and an IDE.
regards
Jurjen
