Module Positions in All Templates (Joomla)
nickblauren
nickblauren posted this 18 September 2015
I've noticed if I insert a module position it only works on that template page (home, etc). If I hover over the hmenu position, I see that you can share it in all templates if you want. Why can't you choose the same in the module position?
Is there a way to just get rid of the extra "templates" within the template? And have one? A la Artisteer?
Thanks!
I've noticed if I insert a module position it only works on that template page (home, etc). If I hover over the hmenu position, I see that you can share it in all templates if you want. Why can't you choose the same in the module position? Is there a way to just get rid of the extra "templates" within the template? And have one? A la Artisteer? Thanks!
nickblauren
nickblauren posted this 19 September 2015
Another great example. I just put a clickable logo (fixed on screen) on the "home" part of the template. Now I have to go duplicate that for "blog, default, etc". There must be a better way to do this.
Stagger Lee posted this 19 September 2015
When you duplicate use paste and share, to avoid unnecessary code in PHP, CSS files.
Just paste gives you unique classes and unique CSS code lines for each template, and it is something you dont want and need in 99% cases.
When you duplicate use paste and share, to avoid unnecessary code in PHP, CSS files. Just paste gives you unique classes and unique CSS code lines for each template, and it is something you dont want and need in 99% cases.
wilderer
Is Solution
wilderer posted this 19 September 2015
Leider funktioniert das nicht überall. Gerade für die unterschiedlichen Auflösungen! Man muss für jeden Bereich (Phone, Tablet usw.) gesonderte Einstellungen treffen in Punkto "Anzeige, Joomla-Position).
Außerdem werden nicht alle gefertigten Modul-Positionen in Joomla aktiviert. Viele Joomla-Modul-Positionen sind einfach nicht benutzbar (Breadcrumbs).
Vielleicht sollte man sich bei den Positionen etwas mehr an den Joomla-Standard halten, auch in der Nummerierung.
Der User sollte auch die Möglichkeit erhalten selbst zu wählen zwischen:
- left, right, top, botton.....
- position-1, position-2, position-3.....
Genau wie in Artisteer!
> When you duplicate use paste and share, to avoid unnecessary code in PHP, CSS files. > Just paste gives you unique classes and unique CSS code lines for each template, and it is something you dont want and need in 99% cases. Leider funktioniert das nicht überall. Gerade für die unterschiedlichen Auflösungen! Man muss für jeden Bereich (Phone, Tablet usw.) gesonderte Einstellungen treffen in Punkto "Anzeige, Joomla-Position). Außerdem werden nicht alle gefertigten Modul-Positionen in Joomla aktiviert. Viele Joomla-Modul-Positionen sind einfach nicht benutzbar (Breadcrumbs). Vielleicht sollte man sich bei den Positionen etwas mehr an den Joomla-Standard halten, auch in der Nummerierung. Der User sollte auch die Möglichkeit erhalten selbst zu wählen zwischen: - left, right, top, botton..... - position-1, position-2, position-3..... Genau wie in Artisteer!
Support Team posted this 21 September 2015
The template includes several already shared positions. Such as Header, Footer ans Sidebars. All the controls positioned in those areas will be shared on the templates with the same settings.
So, for example, adding a logo in Header section will automatically show it on all the other templates if the header is enabled there.
Also if there is any issue in the responsive modes, please describe them in more details so we could reproduce it.
About the position names. You can set the module position name inside Themler.
The breadcrumbs position has some peculiarities, you can read about them in the documentation:
http://answers.themler.com/articles/4182/breadcrumbs
Hi, The template includes several already shared positions. Such as Header, Footer ans Sidebars. All the controls positioned in those areas will be shared on the templates with the same settings. So, for example, adding a logo in Header section will automatically show it on all the other templates if the header is enabled there. Also if there is any issue in the responsive modes, please describe them in more details so we could reproduce it. About the position names. You can set the module position name inside Themler. The breadcrumbs position has some peculiarities, you can read about them in the documentation: http://answers.themler.com/articles/4182/breadcrumbs Sincerely, Hella
