Yes, you can use a PST converter that supports batch processing. This is useful when you have several PST files because you can add them together instead of converting each file separately. Depending on the tool, you can select formats such as MBOX, EML, MSG, PDF, or CSV and save the converted data to your preferred location. Just check the converted files afterward to make sure the emails and attachments are intact.
