posted this
28 September 2015
The ability to add the section ID will be implemented in the next update.
@websitefixerupper , please make sure that you have installed all the updates available (the red circle in the top application bar) and that you are using the latest Themler version:
http://downloads.themler.com/Themler.1.0.93.95c52.exe
Then try to add the section in the blank default theme. If the issue happens only with your early edited themes, please attach one of them for the investigation. In case it happens with the default theme, then please create a private topic and provide a TeamViewer access so our developers could see the issue.
Also you can try to reinstall the application completely to see if that helps.
