I can't run Themler
swdvab
swdvab posted this 20 September 2015
I can't run themler.
it's not working on PC, not work on my website. What happening.
I working on the template 7 days and now i cant open it. not for saving the theme.
what i can do.
Hello I can't run themler. it's not working on PC, not work on my website. What happening. I working on the template 7 days and now i cant open it. not for saving the theme. what i can do.
Support Team posted this 21 September 2015
as I understand you're working with online Joomla version. What exactly happen when you click 'Edit Template' button under the template options?
Please also provide access to your Joomla admin back end.
I moved the topic to private so you may post the access credentials here.
Hello, as I understand you're working with online Joomla version. What exactly happen when you click 'Edit Template' button under the template options? Please also provide access to your Joomla admin back end. I moved the topic to private so you may post the access credentials here. Regards, Aileen
swdvab
swdvab posted this 21 September 2015
Not only online version but, offline version to.
Aafter 10 hours it's begining to work.
Only what I can see It's "Try to connect to - https://templates.themler.com/"
but now all fine.
thank you
Not only online version but, offline version to. Aafter 10 hours it's begining to work. Only what I can see It's "Try to connect to - https://templates.themler.com/" but now all fine. thank you
I'm glad that you've managed to revolve your issue.
Ivan
Hi, I'm glad that you've managed to revolve your issue. Please let us know if you have any further questions. Thanks, Ivan
