Yes, a corrupted PST file may still be convertible if the mailbox data is recoverable. The important thing is to first scan the PST and determine how much of the data can be accessed rather than trying to open it repeatedly in Outlook.
A typical approach is:
Create a copy of the original PST so the source file remains unchanged.
Load the copied PST into a PST recovery/conversion tool.
Scan the file for recoverable mailbox items.
Preview the available emails, folders, contacts, and attachments.
Select the required data.
Choose an output format such as MBOX, EML, MSG, PDF, or CSV.
Export the recovered data to a new location.
Check several converted emails and attachments after the process.
Tools such as SysInfo PST Converter can be useful when working with inaccessible or corrupted PST files because they provide scanning and preview options before conversion. The actual amount of recoverable data depends on the extent of corruption, so keeping the original PST untouched is important.
Yes, a corrupted PST file may still be convertible if the mailbox data is recoverable. The important thing is to first scan the PST and determine how much of the data can be accessed rather than trying to open it repeatedly in Outlook. A typical approach is: Create a copy of the original PST so the source file remains unchanged. Load the copied PST into a PST recovery/conversion tool. Scan the file for recoverable mailbox items. Preview the available emails, folders, contacts, and attachments. Select the required data. Choose an output format such as MBOX, EML, MSG, PDF, or CSV. Export the recovered data to a new location. Check several converted emails and attachments after the process. Tools such as SysInfo [PST Converter][1] can be useful when working with inaccessible or corrupted PST files because they provide scanning and preview options before conversion. The actual amount of recoverable data depends on the extent of corruption, so keeping the original PST untouched is important. [1]: https://www.sysinfotools.com/pst-converter.phpLast edited 01 October 2026 by willjacks374
