Can't install Themler Template in Magento
Andy77
Andy77 posted this 17 October 2014
Hello together,
I created a template for megento. I downloaded the zip and try to install the theme in magento how you discribe it in the manual. But by uploading I receive all time the same error:
CONNECT ERROR: Package file is invalid
Invalid package name, allowed: [a-zA-Z0-9_-] chars
Invalid version, should be like: x.x.x
Invalid stability
Invalid date, should be YYYY-DD-MM
Invalid channel URL
Empty authors section
Empty package contents section
What is going wrong here?
Thanks in advance
Andy
Hello together, I created a template for megento. I downloaded the zip and try to install the theme in magento how you discribe it in the manual. But by uploading I receive all time the same error: CONNECT ERROR: Package file is invalid Invalid package name, allowed: [a-zA-Z0-9_-] chars Invalid version, should be like: x.x.x Invalid stability Invalid date, should be YYYY-DD-MM Invalid channel URL Empty authors section Empty package contents section What is going wrong here? Thanks in advance Andy
13 Comments
Support Team posted this 17 October 2014
Hello Andy,
Please let us know what version of Magento you use so that we could try reproducing the issue exactly. Also please specify whether the same error appears if you install a default Themler theme (downloadable from http://billionthemler.com/Download/Magento). Thank you for this.
Hello Andy, Please let us know what version of Magento you use so that we could try reproducing the issue exactly. Also please specify whether the same error appears if you install a default Themler theme (downloadable from http://billionthemler.com/Download/Magento). Thank you for this. Sincerely, BillionDigital Team
Andy77
I use magento community version 1.9.0.1
Also if I try to install the default theme the same error comes up.
Thanks in advance and best regards
Andy
Hello, I use magento community version 1.9.0.1 Also if I try to install the default theme the same error comes up. Thanks in advance and best regards Andy
Hello Andy,
Sorry for this confusion. Currently Themler themes can be installed in Magento via FTP as unpacked theme only (see section "Installation via FTP (Unpacked Template)"). We will update the information on the http://billionthemler.com/Download/Magento page as soon as possible so that it describes the correct way only.
Hello Andy, Sorry for this confusion. Currently Themler themes can be installed in Magento via FTP as unpacked theme only (see section "Installation via FTP (Unpacked Template)"). We will update the information on the http://billionthemler.com/Download/Magento page as soon as possible so that it describes the correct way only. Sincerely, BillionDigital Team
vmamet
vmamet posted this 04 December 2014
I had the same issue.
I uploaded the files via FTP
Configured the Configuration Page .... putting default to "mytemplate"
When I click on Edit under Billionthemler
It opens the default magento 1.9 theme and not my theme
And when I try to edit the default theme ... I can't select any elements and change them !
Any Solution ?
I had the same issue. I uploaded the files via FTP Configured the Configuration Page .... putting default to "mytemplate" When I click on Edit under Billionthemler It opens the default magento 1.9 theme and not my theme And when I try to edit the default theme ... I can't select any elements and change them ! Any Solution ?
Support Team posted this 04 December 2014
Please specify whether you have merged /app and /skin folders with the corresponding folders in Magento and also let us know what browser you use. Thanks for this.
Best reagrds,
Hello, Please specify whether you have merged /app and /skin folders with the corresponding folders in Magento and also let us know what browser you use. Thanks for this. Best reagrds, Nettie, BillionDigital Team
Hi Andy77 and vmamet,
An update: it looks like you have done everything correctly: we could reproduce the issue and have forwarded it to our engineers.
I'll keep you posted on the progress at this point.
Hi Andy77 and vmamet, An update: it looks like you have done everything correctly: we could reproduce the issue and have forwarded it to our engineers. I'll keep you posted on the progress at this point. Sincerely, Nettie, BillionDigital Team
Support Team posted this 05 December 2014
Please try to go to System tab >> Configuration >> General >> Design and in the Package section please rename the current package name to default. This should help.
Hello, Please try to go to System tab >> Configuration >> General >> Design and in the Package section please rename the current package name to **default**. This should help. Sincerely, Nettie, BillionDigital Team
vmamet
vmamet posted this 08 December 2014
Perfect ... worked for me !
it was on rwd ....... i put default ..... and now it is ok
Perfect ... worked for me ! it was on rwd ....... i put default ..... and now it is ok Thanks
vmamet
Just another small bug .... for security reason "admin" in www.mydomain.com/admin to access the admin section has been changed during installation to www.domain/com/somethingelse
When I click on magento in billionthemler ..... it is redirecting me to "admin" and not "somethingelse"
regards
Just another small bug .... for security reason "admin" in www.mydomain.com/admin to access the admin section has been changed during installation to www.domain/com/somethingelse When I click on magento in billionthemler ..... it is redirecting me to "admin" and not "somethingelse" regards
Support Team posted this 08 December 2014
Thank you, we have forwarded the request to our developers and will let you know once this change is implemented.
Best regards,
Hello, Thank you, we have forwarded the request to our developers and will let you know once this change is implemented. Best regards, Nettie, BillionDigital Team
Kos
Kos posted this 26 April 2016
Hi, the same for me here,
When I click EDIT on theme - it's opens RWD them....
I have Multiwebsite.
Default Design and Theme config is set as per instructions as Default and "MyThemeName"
Two websites using different themes. One is RWD another "MythemName"
FrontEnd is loading the two themes accordingly.
but when I want to edit With Themler - it's loading RWD theme, and not "MyThemeName"
any advise?
Kos
Hi, the same for me here, When I click EDIT on theme - it's opens RWD them.... I have Multiwebsite. Default Design and Theme config is set as per instructions as Default and "MyThemeName" Two websites using different themes. One is RWD another "MythemName" FrontEnd is loading the two themes accordingly. but when I want to edit With Themler - it's loading RWD theme, and not "MyThemeName" any advise? Regards, Kos
Support Team posted this 27 April 2016
Hello Kos,
The original issue from the topic has been fixed a long ago so it looks like a different issue. Could you please create a new private topic and provide temporary access to your website for investigation?
Hello Kos, The original issue from the topic has been fixed a long ago so it looks like a different issue. Could you please create a new private topic and provide temporary access to your website for investigation? Sincerely, Nettie, BillionDigital Team
ma.ro.so01234567890
ma.ro.so01234567890 posted this 30 August 2023
The error message you're encountering indicates that there's an issue with the structure or contents of the theme package you're trying to install in Magento.
Detroit cost of drywall
The error message you're encountering indicates that there's an issue with the structure or contents of the theme package you're trying to install in Magento. [Detroit cost of drywall][1] [1]: https://www.google.com/maps?cid=15429711113675598997
