Responsive Horizontal Menu Not Displaying Properly
Craig
Craig posted this 21 September 2015
I'm not sure if I'm doing something wrong or if this is a bug. I have a horizontal menu that displays fine in desktop mode. If I narrow the window or pull the page up on my phone, I get the hamburger menu. But if I expand the menu, it shows the desktop horizontal menu.
http://workforceninjas.com/
As a side note, I wanted the logo and search box to align with the left and right edges of the sheet but I wanted the menu to be page width. So I moved the menu into its own container and set it to page width. I have to center the menu items otherwise they are up against the very edge of the window. Is there a way to left or right align the menu items to the sheet while still having the menu background the full page width?
Craig
I'm not sure if I'm doing something wrong or if this is a bug. I have a horizontal menu that displays fine in desktop mode. If I narrow the window or pull the page up on my phone, I get the hamburger menu. But if I expand the menu, it shows the desktop horizontal menu. http://workforceninjas.com/ As a side note, I wanted the logo and search box to align with the left and right edges of the sheet but I wanted the menu to be page width. So I moved the menu into its own container and set it to page width. I have to center the menu items otherwise they are up against the very edge of the window. Is there a way to left or right align the menu items to the sheet while still having the menu background the full page width? Thanks, Craig
Support Team posted this 23 September 2015
Hello Craig,
  1. Currently the horizontal menu opens as expected on your live website. Is the issue still actual?
  2. Please try selecting the "Full Background" option for the menu. The menu items will be aligned with regard to the Sheet but the menu area will be page width:
Hello Craig, 1. Currently the horizontal menu opens as expected on your live website. Is the issue still actual? 2. Please try selecting the *"Full Background"* option for the menu. The menu items will be aligned with regard to the Sheet but the menu area will be page width: !i66.png! Sincerely, Nettie, BillionDigital Team
Craig
Craig posted this 23 September 2015
Thanks for the reply. I ended up putting the menu in a section and set the section length to Full Background. But if I set the menu->Align to center, I still don't get the responsive menu. Once I set it to left, I got the responsive menu. So this may still be a bug that needs fixing but I prefer the left align when it's in the Full Background section so my problem is solved.
Craig
Thanks for the reply. I ended up putting the menu in a section and set the section length to Full Background. But if I set the menu->Align to center, I still don't get the responsive menu. Once I set it to left, I got the responsive menu. So this may still be a bug that needs fixing but I prefer the left align when it's in the Full Background section so my problem is solved. Thanks, Craig
Support Team posted this 24 September 2015
We're aware about this issue and our developers are working on it.
It will be fixed in one of the next Themler updates.
Please let us know if you have any other questions/issues.
Hi, > But if I set the menu->Align to center, I still don't get the responsive menu. We're aware about this issue and our developers are working on it. It will be fixed in one of the next Themler updates. Please let us know if you have any other questions/issues. Thank you, Olivia
eviltwin
eviltwin posted this 28 September 2015
this is occurring with both wordpress and joomla templates.
I do not have an option to modify the length of the horizontal menu. It is not available. This needs to be corrected.
this is occurring with both wordpress and joomla templates. I do not have an option to modify the length of the horizontal menu. It is not available. This needs to be corrected.
Stagger Lee posted this 28 September 2015
Under "Add extension" options.
