Is possible start a new project with a blank theme to add new divs (containers, header, etc) ?
Hello Is possible start a new project with a blank theme to add new divs (containers, header, etc) ? Thanks
Hello Is possible start a new project with a blank theme to add new divs (containers, header, etc) ? ThanksHi,
There is no such option, but you can delete the major controls like Sheet, Header and Footer and then build the template from the blank page.
If I delete the major controls like Sheet, Header and Footer I am not able to replace them. I am not able to place any control on the page anymore.
Hi, If I delete the major controls like Sheet, Header and Footer I am not able to replace them. I am not able to place any control on the page anymore.Hi,
Thanks for pointing to this. The problem will be fixed in the next updates.
I'd like to re-open this question and ask why there is no option to start with a blank Wordpress theme?
You say there is no option but we can just delete the controls that are there - but this is why we want the option to start with a blank template.
When starting a new theme, if the first task we have to do is delete all the sections and controls, this is very frustrating and not user friendly.
So I want to suggest this as a new feature - surely this should be a standard option and should not take long to add to Themler.
What do you say?
> Hi, > > There is no such option, but you can delete the major controls like Sheet, Header and Footer and then build the template from the blank page. > > Sincerely, > Hella > BillionDigital Team I'd like to re-open this question and ask why there is no option to start with a blank Wordpress theme? You say there is no option but we can just delete the controls that are there - but this is why we want the option to start with a blank template. When starting a new theme, if the first task we have to do is delete all the sections and controls, this is very frustrating and not user friendly. So I want to suggest this as a new feature - surely this should be a standard option and should not take long to add to Themler. What do you say?Hi,
We've already added your request to our wish list.
In the meantime you can create own blank theme and use to start projects.
Themler Team
