anneke
posted this
30 September 2015
I need to a shortcodes in to a html block. I know there are shortcode inserts, but I can't add html in to the shortcode fields. So, thats not the solution.
I tried to find html/php codes instead of shortcodes (for example: <?php anythingpopup('[anything-popup:1]');=""?> )
But the HTML blocks will change this to comments in the code?
I want to make a popup with a Wordpress plugin. After clicking on a link (I added in to the HTML) a popup has to be visible.
Hope someone can help!
Thanks in advance
Hi, I need to a shortcodes in to a html block. I know there are shortcode inserts, but I can't add html in to the shortcode fields. So, thats not the solution. I tried to find html/php codes instead of shortcodes (for example: <?php anythingpopup('[anything-popup:1]');=""?> ) But the HTML blocks will change this to comments in the code? I want to make a popup with a Wordpress plugin. After clicking on a link (I added in to the HTML) a popup has to be visible. Hope someone can help! Thanks in advance
