Button in slider
guy
guy posted this 30 September 2015
Hello i'd like to have buttons on some sliders, but i want them on every slide and now if i do that they disapear and come back on everyslide.
Their position is also different on different screen. It would be great to have them locked in my div, like with a z-index but i didn't manage to do that.
Hello i'd like to have buttons on some sliders, but i want them on every slide and now if i do that they disapear and come back on everyslide. Their position is also different on different screen. It would be great to have them locked in my div, like with a z-index but i didn't manage to do that. !header.png!
9 Comments
Support Team posted this 30 September 2015
Unfortunately there is no option to set the buttons to be positioned over the slider, you can only set them in each slide.
Regarding positioning on different screens, you can switch to each responsive mode and set the content as desired.
Hi, Unfortunately there is no option to set the buttons to be positioned over the slider, you can only set them in each slide. Regarding positioning on different screens, you can switch to each responsive mode and set the content as desired. Sincerely, Hella
lesergei
lesergei posted this 30 September 2015
Here's a solution. Add your button in your slide and change its position for "fixed on screen."
Bonne chance...
Hello, Here's a solution. Add your button in your slide and change its position for "fixed on screen." Bonne chance...
lesergei
lesergei posted this 05 October 2015
I just tested and it does not work, the buttons remain fixed when you scroll the page they exit the slideshow.
Hi, I just tested and it does not work, the buttons remain fixed when you scroll the page they exit the slideshow.
DouzanStudio
DouzanStudio posted this 05 October 2015
Nice buttons btw :)
Hi, Nice buttons btw :)
Support Team posted this 06 October 2015
Could you please explain this issue in some more details so we can try to reproduce it.
Ivan
Hi, >I just tested and it does not work, the buttons remain fixed when you scroll the page they exit the slideshow. Could you please explain this issue in some more details so we can try to reproduce it. Thanks, Ivan
guy
guy posted this 06 October 2015
Yes i solved the problem and it look really nice, no disapear between sliders and it's fixed on every slide/screen.
I just put them in a box absolute in slider and the button are absolute in box, and after some last margin and padding stuff, i have a really nice display on the website :)
Yes i solved the problem and it look really nice, no disapear between sliders and it's fixed on every slide/screen. I just put them in a box absolute in slider and the button are absolute in box, and after some last margin and padding stuff, i have a really nice display on the website :)
Nice to hear that you have found a solution. Feel free to contact us in any other occasion.
Nice to hear that you have found a solution. Feel free to contact us in any other occasion. Sincerely, Hella
Damy
Damy posted this 07 October 2015
I have a box absolute on slider and it fade out with the slider ( mean it disappear with slide change) .. how did you fix that issue ? if you can explain a bit ?
How to put Box or any other component on top of slider not on slide ?
Regards!
> Yes i solved the problem and it look really nice, no disapear between sliders and it's fixed on every slide/screen. > > I just put them in a box absolute in slider and the button are absolute in box, and after some last margin and padding stuff, i have a really nice display on the website :) I have a box absolute on slider and it fade out with the slider ( mean it disappear with slide change) .. how did you fix that issue ? if you can explain a bit ? How to put Box or any other component on top of slider not on slide ? Regards!
guy
guy posted this 08 October 2015
It's in the slider, my box is absolute in slider and my buttons are absolute in the box, but i had to create the exat same box on my multiple slide if i remember correctly, if it's still not working i'll take a look and see what else i changed.
