How to add prestashop module into a template?
MrGreen
MrGreen posted this 30 September 2015
how to place a prestashop module (menu or specific filter) on the themler template ?
Hello, how to place a prestashop module (menu or specific filter) on the themler template ? Thanks
MrGreen
For exemple, i don't want to use the themler module menu.
I want to user other... How to ?
For exemple, i don't want to use the themler module menu. I want to user other... How to ?
Support Team posted this 01 October 2015
The Themler menu is positioned in the displayNavigationBar hook, You can disable it and add the desired menu module in any hook available.
Hi, The Themler menu is positioned in the displayNavigationBar hook, You can disable it and add the desired menu module in any hook available. Sincerely, Hella
MrGreen
MrGreen posted this 01 October 2015
Ok, but when i try to do that (i click on "transplant a module"), i've the message :
This module cannot be transplanted to this hook.
it's for the "Top horizontal menu"
is there a to define or put or know the "position" of a block or box on themler ?
(like to add a displayHeader position on the template)
Ok, but when i try to do that (i click on "transplant a module"), i've the message : This module cannot be transplanted to this hook. it's for the "Top horizontal menu" is there a to define or put or know the "position" of a block or box on themler ? (like to add a displayHeader position on the template)
MrGreen
Is Solution
It's seem to resolve my problem : https://answers.themler.com/articles/4475/prestashop-hook-top-column
How to mark "resolved" to a post ? ;)
It's seem to resolve my problem : https://answers.themler.com/articles/4475/prestashop-hook-top-column How to mark "resolved" to a post ? ;)
Tammie
Tammie posted this 02 October 2015
Click on the check mark:
Tammy
Hello, Click on the check mark: !resolved.png! Sincerely, Tammy
