Menu width - Full page
Ellie
Ellie posted this 16 April 2014
My Header width is set to Full page. Can I do the same for a horizontal menu?
Rory
Hi, My Header width is set to Full page. Can I do the same for a horizontal menu? ![](http://attachments.forum.billiondigital.com/86/86/menu-length.png) Thanks, Rory
Support Team posted this 17 April 2014
Hi Rory!
The Length option appears for the menu when it is located outside the header. Then you can set the Full page width.
In any case I'm not sure whether the same option should be available once the menu is placed inside the header.
Best regards,
Hi Rory! The Length option appears for the menu when it is located outside the header. Then you can set the Full page width. In any case I'm not sure whether the same option should be available once the menu is placed inside the header. Best regards, Hella
Eugene
Is Solution
Eugene posted this 20 April 2014
The Length option is hidden for every control, which is placed inside another.
E.g. Menu inside Header or Menu inside Columns have this option hidden.
But Menu outside Header or Sheet will have the option enabled.
The Length option is hidden for every control, which is placed inside another. E.g. Menu inside Header or Menu inside Columns have this option hidden. But Menu outside Header or Sheet will have the option enabled.
