how to add custom fonts like arabic fonts ??
how to add custom fonts like arabic fonts ??Last edited 06 November 2014 by Support Team
Unfortunately this feature is not supported at this time. Themler supports only web safe fonts and google fonts.
But you can add custom font manually. For this you simply need to add @font-face rule to the Theme Settings >> Additional CSS and override default style of body and headings with the following code:
body, h1, h2, h3, h4, h5, h6 {font-family: 'YOUR_FONT';}
This default font will be used when "No font/inherit" option is specified.
You can also add the fonts using the Google Fonts, the instruction can be seen here:
https://developers.google.com/fonts/docs/getting_started
The tag should be added in the Theme Settings >> Additional HTML tab and the CSS code in th Theme Settings >> Additional CSS.
Hi there,
is it now possible to integrate custom fonts?
Thanks a lot and have a nice Day
claudia
Hi there, is it now possible to integrate custom fonts? Thanks a lot and have a nice Day claudiaHello Claudia,
pleas follow the suggestion from the topic http://answers.themler.com/questions/41734/how-to-add-chinese-font-like-microsoft-yahei
Dear Themler Support
Where i can find "Themler Settings >> Additional CSS" in the actual Themler version? Is the setting somewhere in Themler or on the admin-backend??
Dear Themler Support Where i can find "Themler Settings >> Additional CSS" in the actual Themler version? Is the setting somewhere in Themler or on the admin-backend??Hi,
It's inside Themler under the Home >> Settings tab.
I've added a custom Google font using the instructions. However, when making the font bold, it looks distorted.
Is there a way I can add the Bold styles of this font as well? https://fonts.google.com/specimen/Manrope
Thanks!
Hi, I've added a custom Google font using the instructions. However, when making the font bold, it looks distorted. Is there a way I can add the Bold styles of this font as well? https://fonts.google.com/specimen/Manrope Thanks!Hello,
The recommended way is to include the link to the font that is already bold, and define it in Font settings ror Additional CSS.
We can add any font using font-face
For Example: In CSS file add the below code
@font-face {
font-family: arabic-font;
src: url(font-name.woff);
p {
font-family: Arabic-font;
Hello Michiel,
Please try using absolute URL for the font files (starting with http://...) and make sure the font files are placed at the mentioned location.
Hello Michiel,
Do these fonts work independently if you use them on a non-Themler simple HTML page?
