I can't use the Themler
michelle5
michelle5 posted this 16 November 2014
I can't use your software on any browser.
I am using a Macbook Pro with Yosemite 10.10 on it.
Everytime I try to do anything in the Themler free version I get the following error:
The webpage at http://billionthemler.com/Cms/LimitExceeded/1632174 has resulted in too many redirects. Clearing your cookies for this site or allowing third-party cookies may fix the problem. If not, it is possibly a server configuration issue and not a problem with your computer.
Learn more about this problem.
Error code: ERR_TOO_MANY_REDIRECTS
Michelle
I can't use your software on any browser. I am using a Macbook Pro with Yosemite 10.10 on it. Everytime I try to do anything in the Themler free version I get the following error: The webpage at http://billionthemler.com/Cms/LimitExceeded/1632174 has resulted in too many redirects. Clearing your cookies for this site or allowing third-party cookies may fix the problem. If not, it is possibly a server configuration issue and not a problem with your computer. Learn more about this problem. Error code: ERR_TOO_MANY_REDIRECTS Michelle
alexjandro
alexjandro posted this 16 November 2014
tambien tengo el mismo problema
trabajo con mac pro y quiero comprar una licencia de Themler y quiero probar a fondo la version gratuita y no puedo desde hace 2/3 dias.
tambien tengo el mismo problema trabajo con mac pro y quiero comprar una licencia de Themler y quiero probar a fondo la version gratuita y no puedo desde hace 2/3 dias.
Support Team posted this 17 November 2014
Hello guys,
we need more input concerning this issue. Just in case please make sure that you're not running several instances at the same time in different browser tabs. If it's not a problem please follow the steps:
1. close tabs with Themler in Chrome
2. press the F12 key beforehand, open the Network tab.
3. open Themler, if you get the same error please make screenshot of Network tab and attach it to this case.
Thank you.
Hello guys, we need more input concerning this issue. Just in case please make sure that you're not running several instances at the same time in different browser tabs. If it's not a problem please follow the steps: 1. close tabs with Themler in Chrome 2. press the F12 key beforehand, open the Network tab. 3. open Themler, if you get the same error please make screenshot of Network tab and attach it to this case. Thank you. Regards, Aileen
We've updated Themler. The reported issue should be solved.
Please try now and let us know the result.
Hi, We've updated Themler. The reported issue should be solved. Please try now and let us know the result. Thank you, Olivia
michelle5
Is Solution
michelle5 posted this 01 January 2015
yes, it works. but now i have a different issue. which i reported under a different post
Support Team posted this 03 January 2015
OK, so I'll mark this case as solved and we'll continue to investigate your new issue in the new ticket.
Hi, OK, so I'll mark this case as solved and we'll continue to investigate your new issue in the new ticket. Sincerely, Hella BillionDigital Team
