posted this
12 October 2015
You started HTML theme and trying to import PrestaShop theme.
The Import from BillionThemes option as well as Import from ZIP allows to import only Themler themes of the appropriate type.
So, to import the PrestaShop theme from shown on the video you should choose PrestaShop CMS instead of HTML on the start screen.
Unfortunately there are no Themler HTML samples on the BillionThemes at this time.
You started **HTML** theme and trying to import **PrestaShop** theme.
The *Import from BillionThemes* option as well as *Import from ZIP* allows to import only **Themler** themes of the appropriate type.
