Removing custom bullets
info12345
info12345 posted this 11 October 2015
I have changed my bullets to an image provided by Themler. For one particular module however I do not want bullet points. I have therefore given it a module class suffix of "nobullets". I then tried the following css:
.nobullets ul{ list-style-type: none; content: none; }
But It does not seem to work.
I have changed my bullets to an image provided by Themler. For one particular module however I do not want bullet points. I have therefore given it a module class suffix of "nobullets". I then tried the following css: > .nobullets ul{ list-style-type: none; content: none; } But It does not seem to work.
14 Comments
Support Team posted this 12 October 2015
Could you please provide us with a temp access to your Joomla back-end so we can try to help you.
I'll move this ticket to private so feel safe to post your credentials here.
Ivan
Hi, Could you please provide us with a temp access to your Joomla back-end so we can try to help you. I'll move this ticket to private so feel safe to post your credentials here. Thanks, Ivan
info12345
info12345 posted this 12 October 2015
It's the Pilmgrim2015 template which has Themler installed too.
The first issue of removing the bullets from the book covers seems to have been addressed.
2nd The bullets are not formatting correctly in the article text e.g. http://dev.internetlinked.com/about there is no space between the bullets and the start of the sentence. Further I can't find an example but I notices once that if the bullet wraps around that the text is not indented properly. I was referred to an online support document about setting margin and intent but this did not seem to help.
Sorry about all these questions but I have been fighting with it for days and just want to get it finished so that I can make the site live :)
If you can just let me know what changes you make so that I don't have to worry you again in the future.
Many thanks for your patient help.
It's the Pilmgrim2015 template which has Themler installed too. The first issue of removing the bullets from the book covers seems to have been addressed. 2nd The bullets are not formatting correctly in the article text e.g. [http://dev.internetlinked.com/about][3] there is no space between the bullets and the start of the sentence. Further I can't find an example but I notices once that if the bullet wraps around that the text is not indented properly. I was referred to an online support document about setting margin and intent but this did not seem to help. Sorry about all these questions but I have been fighting with it for days and just want to get it finished so that I can make the site live :) If you can just let me know what changes you make so that I don't have to worry you again in the future. Many thanks for your patient help. [1]: http://dev.internetlinked.com/administrator [2]: http://dev.internetlinked.com/blog/books-l/182/all_category [3]: http://dev.internetlinked.com/about
Support Team posted this 13 October 2015
Hello Andre,
1.http://dev.internetlinked.com/ - I do not see bullets on book covers at this page
May be I'm looking to wrong place? Where I could see the issue?
  1. to add space between bullet icon and text on About page open this page in Themler, select Posts >>Post Content >> More Styles >> Bullet List >> Icon section > Shape >>Margin >> Margin Options
and specify right margin, e.g.
Hello Andre, 1.http://dev.internetlinked.com/ - I do not see bullets on book covers at this page !Books.png! May be I'm looking to wrong place? Where I could see the issue? 2. to add space between bullet icon and text on About page open this page in Themler, select Posts >>Post Content >> More Styles >> Bullet List >> Icon section > Shape >>Margin >> Margin Options !OpenMargin.png! and specify right margin, e.g. !MarginResult.png! Regards, Aileen
info12345
info12345 posted this 13 October 2015
Thanks :) Sorted
Thanks :) Sorted
info12345
Ok this half works. If you look at http://dev.internetlinked.com/about/belief (halfway down the page) you will see that there is no indent when a bullet wraps onto a new line. How do I fix this?
Ok this half works. If you look at [http://dev.internetlinked.com/about/belief][1] (halfway down the page) you will see that there is no indent when a bullet wraps onto a new line. How do I fix this? [1]: http://dev.internetlinked.com/about/belief
Please try to also set the left margin to about -23px in the same window as shown in the screen shot above.
Hi, Please try to also set the left margin to about -23px in the same window as shown in the screen shot above. Sincerely, Hella
info12345
Nearly there. It is now layed out correctly except that the whole lot needs to be pushed right to be in line with the paragraphs.
info12345
Added 20px to Padding and all is sweet :) Thanks
You're welcome.
Just let us know if you have any further questions.
Ivan
Hi, You're welcome. Just let us know if you have any further questions. Thanks, Ivan
admin166
admin166 posted this 21 November 2018
hello
I did it the way I said. But I don't see any distance between text and dots.
See attachment. What is wrong?
Best regards
hello I did it the way I said. But I don't see any distance between text and dots. See attachment. What is wrong? Best regards
admin166
admin166 posted this 28 November 2018
My issue is solved. I trun everything back I have startet again :-)
Hello My issue is solved. I trun everything back I have startet again :-)
Support Team posted this 30 November 2018
Great!
Hi, Great! Please let us know if you have any further questions.
xzt39618
xzt39618 posted this 07 October 2025
The CIS-CSM Exam Questions requires deep understanding of ServiceNow's Customer Service Management application suite and its core functionality. ExamsTrack's question bank thoroughly covers essential topics including case management, knowledge management, service catalog configuration, and omnichannel support specific to customer service environments. Through detailed scenario-based questions, you'll develop the skills needed to configure CSM applications effectively and understand how they integrate to create comprehensive customer service ecosystems.
The **[CIS-CSM Exam Questions][1]** requires deep understanding of ServiceNow's Customer Service Management application suite and its core functionality. ExamsTrack's question bank thoroughly covers essential topics including case management, knowledge management, service catalog configuration, and omnichannel support specific to customer service environments. Through detailed scenario-based questions, you'll develop the skills needed to configure CSM applications effectively and understand how they integrate to create comprehensive customer service ecosystems. [1]: https://www.examstrack.com/servicenow-dumps/cis-csm-exam
vaanshsharmaa
vaanshsharmaa posted this 26 February 2026
The Call Girl Gurgaon provide beautiful escorts who deliver sensual experiences. The experience offers safe yet unforgettable enjoyment.
The [Call Girl Gurgaon][1] provide beautiful escorts who deliver sensual experiences. The experience offers safe yet unforgettable enjoyment. [1]: http://www.deekshita.in/gurgaon-call-girls.html
