Delete vertical menu in footer
Seppe
Seppe posted this 11 October 2015
Good evening
In some themes we can download from billionthemes, there is a vertical menu in the footer.
For some reason, it's not possible to delete this. Not if I try the joomla position, nor the vertical menu
The error I get:
Remove {0}
REMOVE_CANNOT_CONTROL_DIALOG_MESSAGE Vertical Menu
This vertical menu is of no use for me, so I don't need it
greetings
Seppe
Good evening In some themes we can download from billionthemes, there is a vertical menu in the footer. For some reason, it's not possible to delete this. Not if I try the joomla position, nor the vertical menu The error I get: ** **Remove {0}** #REMOVE_CANNOT_CONTROL_DIALOG_MESSAGE Vertical Menu ** This vertical menu is of no use for me, so I don't need it greetings Seppe
Support Team posted this 12 October 2015
Please provide the links to some exact themes that do have this issue.
Hi, Please provide the links to some exact themes that do have this issue. Sincerely, Hella
Seppe
Seppe posted this 12 October 2015
Good afternoon Hella
After a couple of hours, I found the solution.
You first have to rename the Joomla Position from 'footer' to something else.
From then on, you can delete the vertical menu.
As long as the vertical menu is placed inside the footer, and the joomla position is also named footer, you can't delete it
greetings
Seppe
Good afternoon Hella After a couple of hours, I found the solution. You first have to rename the Joomla Position from 'footer' to something else. From then on, you can delete the vertical menu. As long as the vertical menu is placed inside the footer, and the joomla position is also named footer, you can't delete it greetings Seppe
Great to hear that you have found solution.
Hi, Great to hear that you have found solution. Sincerely, Hella
Seppe
Yes, I put my solution over here
Maybe there are other people experiencing the same issue
greetings
Seppe
Hello Yes, I put my solution over here Maybe there are other people experiencing the same issue greetings Seppe
