I did a database update and now no longer works themler, I see on the page of the website of my client instead of the programming of the theme, I have combined a mess how can I fix?
Thank you in advance.
As a possible solution please try to completely remove your current installation (select Remove CMS content option) and then install the latest version from our website.
Ivan
but I lose the wordpress theme that I created, how can I make them to save it?
but I lose the wordpress theme that I created, how can I make them to save it?Hi,
Your WP themes are stored in the following folder:
C:\ProgramData\Themler\hd_data\themler_some_digits\wordpress\wp-content\themes
Simply copy it to your PC and feel free to remove CMS content when uninstalling Themler application.
Ivan
now it works, I uninstalled also cms, after I will try to reinsert the saved times.
Imported all the theme as your directions. Everything works perfectly.
Thanks again you have saved a lot of time to work.
Thanks thanks thanks
If you want to put this post in view at all could also be interesting for other users.
Imported all the theme as your directions. Everything works perfectly. Thanks again you have saved a lot of time to work. Thanks thanks thanks If you want to put this post in view at all could also be interesting for other users.Hi,
Thanks, I have moved the case to public. Nice to hear that all is working fine now. Feel free to contact us in any other occasion.
