Custom CSS to remove bullet
info12345
info12345 posted this 14 October 2015
I am wanting to remove the bullets from the Docman modules on the left of the page at http://www.pilgrimpassingthrough.com/other/trumpet-music
I have given the modules the following module class suffix
nobullets
And added the following custom CSS
.nobullets ul {
content:none!important;
But it does not seem to work
I am wanting to remove the bullets from the Docman modules on the left of the page at [http://www.pilgrimpassingthrough.com/other/trumpet-music][1] I have given the modules the following module class suffix > nobullets And added the following custom CSS .nobullets ul { content:none!important; } But it does not seem to work [1]: http://www.pilgrimpassingthrough.com/other/trumpet-music
6 Comments
Support Team posted this 14 October 2015
Please use this code:
.nobullets ul > li:before{
Hi, Please use this code: .nobullets ul > li:before{ content:none!important; } Sincerely, Hella
info12345
Thanks, nearly there. That got rid of the bullet but left the space for the bullet. How do I remove the space i.e. move the text across to the right a little?
Support Team posted this 15 October 2015
I'm a little bit confused. You meant that you want the text to be moved to the left where the bullet was? In this case please use this code:
.nobullets ul {
    padding-left: 0!important;
Hi, I'm a little bit confused. You meant that you want the text to be moved to the left where the bullet was? In this case please use this code: .nobullets ul { padding-left: 0!important; } Sincerely, Hella
info12345
info12345 posted this 15 October 2015
Perfect, thanks :)
Perfect, thanks :)
You are welcome.
davidwarnar8t8
davidwarnar8t8 posted this 19 November 2025
To remove the bullets from the Docman modules on your site, you can use your custom module class suffix and apply targeted CSS to hide the default list styling. For example, adding a rule like ` will effectively remove the bullets and align the items neatly without indentation. This approach ensures that your modules maintain a clean and professional appearance while preserving their functionality. Specifically, for your anchor preschool enrichment classes this method will make the list of resources or files under that module appear visually streamlined, allowing visitors to focus directly on the content rather than the bullet points, which is particularly useful for presenting educational materials clearly.
If you want, I can write the exact CSS snippet ready to paste into your Joomla template for the ` class. Do you want me to do that?
To remove the bullets from the Docman modules on your site, you can use your custom module class suffix and apply targeted CSS to hide the default list styling. For example, adding a rule like ` will effectively remove the bullets and align the items neatly without indentation. This approach ensures that your modules maintain a clean and professional appearance while preserving their functionality. Specifically, for your anchor [preschool enrichment classes][1] this method will make the list of resources or files under that module appear visually streamlined, allowing visitors to focus directly on the content rather than the bullet points, which is particularly useful for presenting educational materials clearly. If you want, I can write the exact CSS snippet ready to paste into your Joomla template for the ` class. Do you want me to do that? [1]: https://rocknessmusic.com/enrichment-classes/
