Help with Themler Cloud
cfwolffschoemaker
cfwolffschoemaker posted this 15 October 2015
Please explain how to access the Themler Cloud environment!
btw I do have a Business Subscription, but I only can access the trial environment.
Thanks in advance
Charles
Hi, Please explain how to access the Themler Cloud environment! btw I do have a Business Subscription, but I only can access the trial environment. Thanks in advance Charles
Support Team posted this 15 October 2015
When you access the themler.com site, there is a Download for CMS button, in the pop-up window you can choose the Try Online option for the desired CMS.
Also where do you see the trial mark or why do you think that the application is in the trial mode?
Hi, When you access the themler.com site, there is a Download for CMS button, in the pop-up window you can choose the Try Online option for the desired CMS. Also where do you see the trial mark or why do you think that the application is in the trial mode? Sincerely, Hella
cfwolffschoemaker
Hi Hella,
The reason that I think I can only/use the trial mode is because I can't save or export a theme. This is the message I get:
Ooops!
Save not allowed on demo server.
And when I try to export, I get the same message.
Charles
Hi Hella, The reason that I think I can only/use the trial mode is because I can't save or export a theme. This is the message I get: Ooops! Save not allowed on demo server. And when I try to export, I get the same message. Regards Charles
Yes, that is right, you can not save on cloud, that is the demo option. But you can download the template as .zip file and then open it in the desktop version or install on the server and edit from your server.
Hi, Yes, that is right, you can not save on cloud, that is the demo option. But you can download the template as .zip file and then open it in the desktop version or install on the server and edit from your server. Sincerely, Hella
cfwolffschoemaker
**strong text**Hi Hella,
Could you clearify the following FAQ for me:
https://answers.themler.com/articles/5546/themler-faq
What is Themler Cloud and what it can be used for?
Themler provides the ability to work in, and store themes on, Themler Cloud. Actually, while working in Themler Cloud, a fully functional CMS is running that allows you to design a Themler theme on it as well as download the theme. Themes, saved on Themler Cloud can then be accessed from your Profile >> Themes section. A theme saved on Themler Cloud can be downloaded to install in your CMS at any time. Please note that in order to be live on your hosting server, the theme should be downloaded and installed on it - the content from your CMS (and not from Themler Cloud) will be used.
Mainly, Themler Cloud should be used for sharing and selling your themes on the BillionThemes Marketplace, as well as for easily evaluating Themler in trial mode.
**strong text**Hi Hella, Could you clearify the following FAQ for me: [https://answers.themler.com/articles/5546/themler-faq][1] [1]: https://answers.themler.com/articles/5546/themler-faq **What is Themler Cloud and what it can be used for?** Themler provides the ability ***to work in, and store themes on, Themler Cloud***. Actually, while working in Themler Cloud, ***a fully functional CMS is running that allows you to design a Themler theme on it as well as download the theme***. Themes, saved on Themler Cloud can then be accessed from your Profile >> Themes section. ***A theme saved on Themler Cloud can be downloaded*** to install in your CMS at any time. Please note that in order to be live on your hosting server, the theme should be downloaded and installed on it - the content from your CMS (and not from Themler Cloud) will be used. Mainly, Themler Cloud should be used for sharing and selling your themes on the BillionThemes Marketplace, as well as for easily evaluating Themler in trial mode.
Sorry, the information on the site was not updated. It was the demo option and that is not available now.
Sorry again for the confusion.
Hi, Sorry, the information on the site was not updated. It was the demo option and that is not available now. Sorry again for the confusion. Sincerely, Hella
