Posts in two columns
Nettie posted this 21 April 2014
Can the Posts area be put into a theme twice? What I am trying to achieve is a sheet consisting of two columns, and two posts per column. However it looks like I can use Posts control only once. So I placed it into the first column. Is there any way to achieve what I wish?
Hello, Can the Posts area be put into a theme twice? What I am trying to achieve is a sheet consisting of two columns, and two posts per column. However it looks like I can use Posts control only once. So I placed it into the first column. Is there any way to achieve what I wish?
Olivia posted this 22 April 2014
It looks like you can't make posts in columns.
Hi, It looks like you can't make posts in columns.
srathje
srathje posted this 01 September 2015
I was looking for this too...Even though the interface doesn't allow for it..you can goto outline --> select posts --> do a copy and paste...it essentially just duplicates the posts though..so probably not what your looking for.
Stagger Lee posted this 02 September 2015
Why you need it when you have this option under Posts tab. Small window above, chose one preset somewhere on the bottom. One with Posts in grid. Then in Layout option chose how many columns you want for different devices.
Support Team posted this 03 September 2015
Please check the Posts Layout option:
Hi, Please check the Posts Layout option: !posts-columns2.png! Thank you, Olivia
