Seppe
posted this
19 October 2015
Ok, I found a work-around to transfer the theme from 1 device to the other.
Device 1: export theme, with the option to include themler
Upload & install the Joomla-theme to the website
Go to the extensions manager and choose for templates
Now select and edit the template you just installed
Press the "edit templat" button.
A Themler-screen opens, and you can work like before.
Now export the theme again as a zip-file. I used the option to include themler.
Device 2: open the standard Themler theme.
File - open - Import from zip - select the .zip you just created.
tadaaaaaaaaaaaaaaaaaa there it is.
It's a huge work-around for something stupid, not?
greetings
Seppe
greetings
Seppe
