Removing hyperlink from Author in blog posts
wuzelina
wuzelina posted this 20 October 2015
Is it possible, to remove the hyperlink from the Authors Name in each post on a blog post layout (wordpress)? I don't want to delete the control completely, since I want to show the author's name. Now it is automatically linked and when clicked it shows all posts from the author, which I don't want.
Thank you in advance for your support, best regards, Dana.
Is it possible, to remove the hyperlink from the Authors Name in each post on a blog post layout (wordpress)? I don't want to delete the control completely, since I want to show the author's name. Now it is automatically linked and when clicked it shows all posts from the author, which I don't want. Thank you in advance for your support, best regards, Dana.
8 Comments
Support Team posted this 21 October 2015
This is the default WP behavior to create a link for such controls as Post Author or Post Date.
As a possible solution please try to add the following code to Themler Settings - Additional CSS:
  .bd-posticonauthor-13 a {
        pointer-events: none;
        cursor: default;
Let us know if it helps.
Ivan
Hi, This is the default WP behavior to create a link for such controls as Post Author or Post Date. As a possible solution please try to add the following code to Themler Settings - Additional CSS: .bd-posticonauthor-13 a { pointer-events: none; cursor: default; } Let us know if it helps. Thanks, Ivan
wuzelina
wuzelina posted this 21 October 2015
Hi Ivan,
Thank you for your help and reply, unfortunately it didn't help: http://web791.login-4.loginserver.ch/2/ The author is still with hyperlink. Any other idea? Appreciate your support.
best regards,
Dana
Hi Ivan, Thank you for your help and reply, unfortunately it didn't help: http://web791.login-4.loginserver.ch/2/ The author is still with hyperlink. Any other idea? Appreciate your support. best regards, Dana
Please try the following code:
.bd-posticonauthor-3 a {
        cursor: default;
It works for your website.
Ivan
Hi, Please try the following code: .bd-posticonauthor-3 a { pointer-events: none; cursor: default; } It works for your website. Thanks, Ivan
wuzelina
Hi Ivan, excellent, now it worked. The previous code had the number 13 in the code instead of 3. Thanks a lot :-))) cheers, Dana
You are welcome. Nice to hear that it works now.
You are welcome. Nice to hear that it works now. Feel free to contact us in any other occasion. Sincerely, Hella
alleminbe
alleminbe posted this 06 August 2016
I would like to do the same with Post Category and Post Tags, would like to remove the hyperlink in blog posts.
Can you please give me the code to put in the Themler Settings - Additional CSS
Hi I would like to do the same with Post Category and Post Tags, would like to remove the hyperlink in blog posts. Can you please give me the code to put in the Themler Settings - Additional CSS Thank you
alleminbe
I managed to copy and adjust the code to this worked fine:
.bd-posticoncategory-7 a {
cursor: default;
.bd-posticontags-8 a {
cursor: default;
I managed to copy and adjust the code to this worked fine: .bd-posticoncategory-7 a { pointer-events: none; cursor: default; } .bd-posticontags-8 a { pointer-events: none; cursor: default; }
Support Team posted this 07 August 2016
You are welcome. Nice to hear that you have found the solution.
You are welcome. Nice to hear that you have found the solution. Sincerely, Hella
