My theme (attached to zip packages where it had been enabled. #11 was the first, 12 us the latest rendition) has a slider carousel enabled but is not displayed after the zip is downloaded and applied to the testing site. The sidebar top component does not appear enabled or present in the test system.
Also attached as "ThemlerLocalOutput.png" is how it looks on my test server.
Note: I had removed the original slider on the default template I started with and after numerous design changes, added it back. Assistance would be appreciated if somehow I didn't do some step that is the root cause.
My theme (attached to zip packages where it had been enabled. #11 was the first, 12 us the latest rendition) has a slider carousel enabled but is not displayed after the zip is downloaded and applied to the testing site. The sidebar top component does not appear enabled or present in the test system. Also attached as "ThemlerLocalOutput.png" is how it looks on my test server. Note: I had removed the original slider on the default template I started with and after numerous design changes, added it back. Assistance would be appreciated if somehow I didn't do some step that is the root cause.
