Error opening theme
Gunzton
Gunzton posted this 26 October 2015
Good day,
I recently made a copy of my theme and was able to rename it to "Backup-1". This caused the following error:
The theme name may contain only alphanumeric symbols and underscore
(A-z, 0-9, '_').
I managed to recover my theme so no help required. To replicate the issue:
  1. Go to file, then click on "Make a Copy As"
  2. Type in "Backup_1", then press the Left Arrow key once to place the caret just after the underscore, then press the Backspace key and then the hyphen key to rename it to "Backup-1"
  3. Click "Make A Copy"
The same can be done with the Rename function listed under File. I'm using Themler v.111 and Google Chrome Version 46.0.2490.80
Good day, I recently made a copy of my theme and was able to rename it to "Backup-1". This caused the following error: > The theme name may contain only alphanumeric symbols and underscore > (A-z, 0-9, '_'). I managed to recover my theme so no help required. To replicate the issue: 1. Go to file, then click on "Make a Copy As" 2. Type in "Backup_1", then press the Left Arrow key once to place the caret just after the underscore, then press the Backspace key and then the hyphen key to rename it to "Backup-1" 3. Click "Make A Copy" The same can be done with the Rename function listed under File. I'm using Themler v.111 and Google Chrome Version 46.0.2490.80
Support Team posted this 26 October 2015
Hi Rudi,
Thank you very much for the cooperation.
I was able to reproduce the issue and forwarded it to our developers.
We'll do our best to fix it ASAP.
Ivan
Hi Rudi, Thank you very much for the cooperation. I was able to reproduce the issue and forwarded it to our developers. We'll do our best to fix it ASAP. Thanks, Ivan
