Problemas al cambiar Background. no surge efecto y me genera error.
(Sorry, error occurred. Your project will be restored.)
Problemas al cambiar Background. no surge efecto y me genera error. (Sorry, error occurred. Your project will be restored.)
Problemas al cambiar Background. no surge efecto y me genera error. (Sorry, error occurred. Your project will be restored.)Que solución puedo tener?
No puedo cambiar el fondo ( background) de mi theme para wordpress
Hi!
This issue should fixed in the next Themler update (tomorrow).
We apologize for the inconvenience.
I have the same problem. When I click in the slider to add a new image I get an error:
Javier,
This error message is generic for most of the errors.
According to a few last error reports from your account this is different problem. It's also fixed but currently fix is on testing stage. The new update with this fix will be available in the near future (today or at most tomorrow).
Sigo teniendo el mismo problema.
click en backgound y error.
alexjandro,
Thank you for contacting us. We'll check error reports from your account. Please stand by.
Javier,
Does the issue continue on your side?
I have started a new theme with the same template, and now it's working. I have renamed the new one with the same name, and the issue now looks solved.
I have started a new theme with the same template, and now it's working. I have renamed the new one with the same name, and the issue now looks solved.Hello Javier,
thank you for the feedback. So we assume that the issue is resolved on your end. If you encounter it again please let us know.
Hello Alexjandro,
please try to open and save the theme right after opening it. Let us know the results.
Hello Alexjandro,
please provide access to your WP admin back end (if you're using a WP hosting), or attach here the zipped theme (if you run WP locally)
Empezare la plantilla de nuevo.
si tengo problemas, avisare
Gracias Team
OK, please let us know about the results.
