woocommerce old version
gerry.drobits
gerry.drobits posted this 04 November 2015
Hi Aileen,
I am using one of your wordpress templates and unfortunately the woocommerce files which are located in the themes are old, how to override them, or can you renew them to woocommerce 2.2 or higher since woocommerce not working anymore in old themes.
Can you help?
Gerry
Hi Aileen, I am using one of your wordpress templates and unfortunately the woocommerce files which are located in the themes are old, how to override them, or can you renew them to woocommerce 2.2 or higher since woocommerce not working anymore in old themes. Can you help? Gerry
gerry.drobits
I get this information regarding integrated woocommerce in this template.
WordPress Environment
Home URL: http://lawoffice-wiedemann.de
Site URL: http://lawoffice-wiedemann.de
WC Version: 2.4.8
Log Directory Writable: ✔ /data/web/e34000/html/apps/wordpress-30445/wp-content/uploads/wc-logs/
WP Version: 4.3.1
WP Multisite: –
WP Memory Limit: 40 MB - We recommend setting memory to at least 64MB. See: Increasing memory allocated to PHP
WP Debug Mode: –
Language: de_DE
Server Environment
Server Info: Apache
PHP Version: 5.6.13-0+deb8u1
PHP Post Max Size: 256 MB
PHP Time Limit: 180
PHP Max Input Vars: 1000
SUHOSIN Installed: –
MySQL Version: 5.6.25
Max Upload Size: 256 MB
Default Timezone is UTC: ✔
fsockopen/cURL: ✔
SoapClient: ✔
DOMDocument: ✔
GZip: ✔
Remote Post: ✔
Remote Get: ✔
Database
WC Database Version: 2.4.8
woocommerce_api_keys: ✔
woocommerce_attribute_taxonomies: ✔
woocommerce_termmeta: ✔
woocommerce_downloadable_product_permissions: ✔
woocommerce_order_items: ✔
woocommerce_order_itemmeta: ✔
woocommerce_tax_rates: ✔
woocommerce_tax_rate_locations: ✔
Active Plugins (10)
BAW Login/Logout menu: by Juliobox – 1.3.3
Conekta Payment Gateway: by Conekta.io – 0.2.1
Artikel duplizieren: by Enrico Battocchi – 2.6
Limit Login Attempts: by Johan Eenfeldt – 1.7.1
SEPA Direct Debit for Subscriptions: by van Stein en Groentjes – 3.2.1
Visual Form Builder: by Matthew Muro – 2.8.6
WooCommerce: by WooThemes – 2.4.8
WP Awesome FAQ: by Liton Arefin – 3.0.2
WP Clone by WP Academy: by WP Academy – 2.1.8
Clef: by Clef – 2.3.0
Settings
Force SSL: –
Currency: EUR (€)
Currency Position: left
Thousand Separator: .
Decimal Separator: ,
Number of Decimals: 2
API
API Enabled: ✔
API Version: 3.0.0
WC Pages
Shop Base: Page not set
Cart: Page not set
Checkout: Page not set
My Account: Page not set
Taxonomies
Product Types: external (external)
grouped (grouped)
simple (simple)
variable (variable)
Theme
Version: 1.0.153
Author URL:
Child Theme: ✕ – If you're modifying WooCommerce or a parent theme you didn't build personally we recommend using a child theme. See: How to create a child theme
WooCommerce Support: ✔
Templates
Overrides: Quatro_new22/woocommerce/archive-product.php version - is out of date. The core version is 2.0.0
Quatro_new22/woocommerce/cart/cart.php version 2.1.0 is out of date. The core version is 2.3.8
Quatro_new22/woocommerce/cart/shipping-calculator.php
Quatro_new22/woocommerce/checkout/form-coupon.php version 1.6.4 is out of date. The core version is 2.2
Quatro_new22/woocommerce/checkout/form-login.php
Quatro_new22/woocommerce/loop/result-count.php
Quatro_new22/woocommerce/loop/sale-flash.php
Quatro_new22/woocommerce/notices/error.php version - is out of date. The core version is 1.6.4
Quatro_new22/woocommerce/notices/notice.php version - is out of date. The core version is 1.6.4
Quatro_new22/woocommerce/notices/success.php version - is out of date. The core version is 1.6.4
Quatro_new22/product-searchform.php
Quatro_new22/woocommerce/single-product.php version - is out of date. The core version is 1.6.4
thanks, can you help?
I get this information regarding integrated woocommerce in this template. ### WordPress Environment ### Home URL: http://lawoffice-wiedemann.de Site URL: http://lawoffice-wiedemann.de WC Version: 2.4.8 Log Directory Writable: ✔ /data/web/e34000/html/apps/wordpress-30445/wp-content/uploads/wc-logs/ WP Version: 4.3.1 WP Multisite: – WP Memory Limit: 40 MB - We recommend setting memory to at least 64MB. See: Increasing memory allocated to PHP WP Debug Mode: – Language: de_DE ### Server Environment ### Server Info: Apache PHP Version: 5.6.13-0+deb8u1 PHP Post Max Size: 256 MB PHP Time Limit: 180 PHP Max Input Vars: 1000 SUHOSIN Installed: – MySQL Version: 5.6.25 Max Upload Size: 256 MB Default Timezone is UTC: ✔ fsockopen/cURL: ✔ SoapClient: ✔ DOMDocument: ✔ GZip: ✔ Remote Post: ✔ Remote Get: ✔ ### Database ### WC Database Version: 2.4.8 : woocommerce_api_keys: ✔ woocommerce_attribute_taxonomies: ✔ woocommerce_termmeta: ✔ woocommerce_downloadable_product_permissions: ✔ woocommerce_order_items: ✔ woocommerce_order_itemmeta: ✔ woocommerce_tax_rates: ✔ woocommerce_tax_rate_locations: ✔ ### Active Plugins (10) ### BAW Login/Logout menu: by Juliobox – 1.3.3 Conekta Payment Gateway: by Conekta.io – 0.2.1 Artikel duplizieren: by Enrico Battocchi – 2.6 Limit Login Attempts: by Johan Eenfeldt – 1.7.1 SEPA Direct Debit for Subscriptions: by van Stein en Groentjes – 3.2.1 Visual Form Builder: by Matthew Muro – 2.8.6 WooCommerce: by WooThemes – 2.4.8 WP Awesome FAQ: by Liton Arefin – 3.0.2 WP Clone by WP Academy: by WP Academy – 2.1.8 Clef: by Clef – 2.3.0 ### Settings ### Force SSL: – Currency: EUR (€) Currency Position: left Thousand Separator: . Decimal Separator: , Number of Decimals: 2 ### API ### API Enabled: ✔ API Version: 3.0.0 ### WC Pages ### Shop Base: Page not set Cart: Page not set Checkout: Page not set My Account: Page not set ### Taxonomies ### Product Types: external (external) grouped (grouped) simple (simple) variable (variable) ### Theme ### Name: Quatro_new22 Version: 1.0.153 Author URL: Child Theme: ✕ – If you're modifying WooCommerce or a parent theme you didn't build personally we recommend using a child theme. See: How to create a child theme WooCommerce Support: ✔ ### Templates ### Overrides: Quatro_new22/woocommerce/archive-product.php version - is out of date. The core version is 2.0.0 Quatro_new22/woocommerce/cart/cart.php version 2.1.0 is out of date. The core version is 2.3.8 Quatro_new22/woocommerce/cart/shipping-calculator.php Quatro_new22/woocommerce/checkout/form-coupon.php version 1.6.4 is out of date. The core version is 2.2 Quatro_new22/woocommerce/checkout/form-login.php Quatro_new22/woocommerce/loop/result-count.php Quatro_new22/woocommerce/loop/sale-flash.php Quatro_new22/woocommerce/notices/error.php version - is out of date. The core version is 1.6.4 Quatro_new22/woocommerce/notices/notice.php version - is out of date. The core version is 1.6.4 Quatro_new22/woocommerce/notices/success.php version - is out of date. The core version is 1.6.4 Quatro_new22/product-searchform.php Quatro_new22/woocommerce/single-product.php version - is out of date. The core version is 1.6.4 thanks, can you help?
Support Team posted this 05 November 2015
Hi Gerry,
The files will be updated with the next major Themler update. However please note that currentyl the latest wooCommerce version is already supported. If there are some specific issues about it, please let us know.
Hi Gerry, The files will be updated with the next major Themler update. However please note that currentyl the latest wooCommerce version is already supported. If there are some specific issues about it, please let us know. Sincerely, Nettie, BillionDigital Team
pvcmloza
pvcmloza posted this 17 July 2024
From a business perspective, VAT operates as a system of credits and offsets. Businesses can reclaim VAT paid on their inputs (purchases and expenses) against the VAT they charge on their outputs (sales). This mechanism helps reduce the cascading effect of taxes and prevents tax pyramiding, where taxes are applied at multiple stages of production without credit for taxes paid at previous stages. As a result, businesses can manage their cash flows more efficiently and avoid undue tax burdens that could otherwise hinder economic growth and investment https://vatcalculatorsuk.co.uk/.
william4700123
william4700123 posted this 10 October 2025
Using an old version of WooCommerce can be tricky sometimes with updates and compatibility issues. I usually double-check numbers and pricing changes with an online calculator to make sure everything adds up correctly before going live.
Using an old version of WooCommerce can be tricky sometimes with updates and compatibility issues. I usually double-check numbers and pricing changes with an [online calculator][1] to make sure everything adds up correctly before going live. [1]: https://besterekenmachine.nl/inch-naar-cm/
