Insert Text Problem
support12
support12 posted this 06 November 2015
When I insert text and type my content after completing I will start to work for others section and now if I need to edit or re-edit the text section , unable to edit that the text line move little up and cannot process further. I have attached the screen shot please give me fast reply.
11 Comments
ClaudiaK
ClaudiaK posted this 06 November 2015
Hi there,
this will happen, everey time, you are using code with <p> inside. Try to use <div> container..
It will work fine.
Have a nice Day
claudia</div>
Hi there, this will happen, everey time, you are using code with &lt;p&gt; inside. Try to use &lt;div&gt; container.. It will work fine. Have a nice Day claudia&lt;/div&gt;
Support Team posted this 06 November 2015
We are sorry for the issue. It should be fixed in the future updates. Meanwhile you can click on the Text control and use the HTML Source options to edit it. That should not affect the final look.
Hi, We are sorry for the issue. It should be fixed in the future updates. Meanwhile you can click on the Text control and use the HTML Source options to edit it. That should not affect the final look. Sincerely, Hella
juddra
juddra posted this 16 November 2016
I am having the same problem with the latest version of Themler. Sometimes when I try to edit the content of a text control I see an insert cursor and I can insert and modify text as expected. Other times I see the 'move' cursor and I am not able to edit the text. Is there a fix or workaround for this?
Support Team posted this 16 November 2016
You can select that control from the Outline in the left panel. If that also does not work, create a private topic with the access to the site back end where we can reproduce the issue.
Hi, You can select that control from the Outline in the left panel. If that also does not work, create a private topic with the access to the site back end where we can reproduce the issue. Sincerely, Hella
david.cleveland
david.cleveland posted this 13 January 2017
This seems to still be a problem. If I insert a text block, I can edit it immediately, however, if I have to re-edit it, all I get is the move cursor, I'm not able to edit the text without using the HTML source button.
Any idea when this will be fixed for good. It;s honestly a bit annoying having to go to the HTML source all the time.
thanks.
This seems to still be a problem. If I insert a text block, I can edit it immediately, however, if I have to re-edit it, all I get is the move cursor, I'm not able to edit the text without using the HTML source button. Any idea when this will be fixed for good. It;s honestly a bit annoying having to go to the HTML source all the time. thanks.
Support Team posted this 17 January 2017
Hello David,
I do not have such problem and I could edit the Text and HTML controls directly in Preview Area at any time. Please create a new private topic where provide access to your WP admin back end and note what exact control demonstrates the issue
Hello David, I do not have such problem and I could edit the Text and HTML controls directly in Preview Area at any time. Please create a new private topic where provide access to your WP admin back end and note what exact control demonstrates the issue regards, Aileen
online9
online9 posted this 30 March 2020
This issue does not seem to have been resolved. Now 2020 and I am having the same problem
Other text blocks are editable, but seemingly randomly, one will only be editable in the HTML editor.
One suggestion above was to use <div> but if I do that, the editor strips all html tags out.
This issue does not seem to have been resolved. Now 2020 and I am having the same problem Other text blocks are editable, but seemingly randomly, one will only be editable in the HTML editor. One suggestion above was to use &lt;div&gt; but if I do that, the editor strips all html tags out.
usif.work
usif.work posted this 28 May 2020
I confirm that this Issue Still Persists.
Support Team posted this 04 June 2020
Have you starting editing content in Wordpress admin panel? If so, please continue to edit it in Wordpress. Or edit the post in Themler from the beginning. This is the way it works.
Hello, Have you starting editing content in Wordpress admin panel? If so, please continue to edit it in Wordpress. Or edit the post in Themler from the beginning. This is the way it works. Sincerely, Nettie
benjamin-der-friese
benjamin-der-friese posted this 20 June 2020
has the themler development cycle ended? i'm sure if you make it more robust, people will be very happy.
Support Team posted this 23 June 2020
Major changed in user interface are not planned for Themler. You are welcome to ask if anything is not clear or if you cannot find anything. You may also consider Nicepage as a possible alternative, it should be more easy (though not as advanced as Themler at the moment).
Hello, Major changed in user interface are not planned for Themler. You are welcome to ask if anything is not clear or if you cannot find anything. You may also consider Nicepage as a possible alternative, it should be more easy (though not as advanced as Themler at the moment). Sincerely, Nettie
